What all is reset when battery is disconnected?
Old 04-19-2011, 11:21 AM
OKsweetrides
OKsweetrides's Avatar
Default What all is reset when battery is disconnected?
What all is reset when the battery is disconnected?
I'm tired of battery drain and am thinking of throwing a battery disconnect in for when I'm away from the car for a long time.
Will it affect the engine tune to have the battery disconnected for weeks at a time?
Old 04-19-2011, 11:28 AM
imavettegirl
imavettegirl's Avatar
yes.
Old 04-19-2011, 12:25 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO it will NOT effect the tune or hurt the BCM/PCM or any other module. In FACT,,, the OWNERS MANUAL recommends "Disconnecting the Battery" for long periods of stowage.
8VETTE7
When you disconnect the battery you will resert the learned LTFT data, all the FOB Memory data and fuel efficiency data will all reset & default to the factory settings. You will also have to re-sync your FOBS. You also cause the PCM to set all of the EMISSIONS NOT READY flage and if you have to get an emissions check, you will have to go thru a number of drive cycles before the FLAGS set to ready.
The LTFT Data will regenerate and learn after a short drive. You just have to reprogram all the seat/dash memory settings manually.
Why not just FIX the problems that are causing your battery to drain??? Its not all that difficult. Insert an AMP meter in series with the NEG Battery Cable and read the DC Amperage that the BCM and PCM draw after the system goes into sleep mode. It should be very close to 0.020 AMPS or 20 milliamps. At that minimum current draw, the car should be able to sit idle for inexcess of 30 days (seen it start without any issues after 2 months of storrage if the battery is in good condition and fully charged!)
Old 04-19-2011, 12:57 PM
OKsweetrides
Thanks for the replies!
As long as the engine tune doesn't go bye-bye I'm a happy camper!
Old 04-19-2011, 01:36 PM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
Agreee with Bill and 8vette7---------- ALSO-----The MORE modded your engine is the LONGER it will take to learn out---
Old 04-19-2011, 02:24 PM
Outlawwed Z06
Outlawwed Z06's Avatar
They make a gaget that plugs into your cig lighter port with a 9v batery in it used for disconecting bateries and saving mem functions, radio presets, ect. not sure how long they last on a 9v batery tho. they sell them at walmart near the car bateries.
Old 04-19-2011, 03:08 PM
imavettegirl
i thought he was referring to the engine settings like fuel trim etc.
Old 04-19-2011, 08:37 PM
Outlawwed Z06
its all parallel circuitry, if the source stays hot, nothing will be lost. but like i said, i dont know how long the 9v will last, or how much amps the car pulls just sitting there.
To What all is reset when battery is disconnected?
Quick Reply: What all is reset when battery is disconnected?
