Need help on power steering
Old 12-12-2023, 12:59 PM
Niels
Niels's Avatar
Default Need help on power steering
My power steering are "heavy" compare to other cars i have tried. The other cars i have tried have a very "light" steering compare to mine.
Are there more than one type of power steering pumps that will fit the car. 1997 C5..
Any suggestions to solve the problem.
Regards
Niels
Old 12-12-2023, 02:06 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There is a magnasteer connector on the rack. it interfaces with the PCM and ABS and uses an ELECRTOMAGNET to boost pump pressure at low speeds and less pressure at high speeds. You should use the DIC and read your DTCs to see if the PCM or ABS DTC and the Rack Magnasteer are functioning properly.
If its not, it will set a PCM DTC.
Check out this post. Its a good read for your issue:
Power steering failure - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 12-12-2023, 02:08 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Look at the rack Magna steer connector and wiring and make sure its in good shape, wires intact and it not damaged.
Old 12-12-2023, 02:15 PM
Niels
Niels's Avatar
Thanks. I will look into it.
To Need help on power steering
Quick Reply: Need help on power steering
