Lowering Question...seeking clarification
After discussing the currtant stance of my FRC with the previous owner I was informed that the way that he lowered it to the currant "stance" was to purchase longer bolts for the rear and to "remove the bolts" from the front. I can see the bolts in the rear and it appears that everything is still connected. I'm concerned about the front though. Once I get the car up in the air and on stands how do I tell which bolt(s) was (were) removed? I've read mixed comments about this way of lowering the C5. How does this affect the handling of my car from stock? I've been looking to do the C6 Z51 swaybars and C6 Z06 shocks upgrades later this summer sometime and want to make sure that the car will still be safe and drivable. Thanks for ANY and all insight that you can provide.
Hi mre1974 -
The front bolts are located on the outermost ends of the transverse spring. The bolt is a 10mm hex bolt, the hex-head protruding above the spring, and a rubber snubber on the end that protrudes under the spring.
The rubber snubber makes contact with the top of the a-arm.
I have never completely removed the adjuster bolt and I personally would not do that. I have read many accounts on this forum of people doing just that with no serious negative effect.
Decide if the ride-height is acceptable to you, and if not, re-install some front bolts.
best regards -
mqqn
best regards -
mqqn
Hi mre1974 -
best regards -
mqqn
best regards -
mqqn
Thanks for the information. When I get a chance I'm going to have to get it up in the air with the wheels off in the front and see if I can find the bolt holes and investigate further. I may have to go to the dealership or see if I can find the bolts online from one of the forum sponcering vendors.
The front bolts aren't available from the dealerships, the bolts are part of the spring and aren't available separately. Hardbar products (Gary Hoffman) sells replacement bolts. There may be other places where you can get them.
In the back you can likely use the bolts you have to get it up high enough.
You will be really surprised how much better it will ride when you get it off of the bump stops.
