Can I move the HUD from my '99 vert to my '01 z?
Got both vettes, my new love is the recently aquired z. Can I take the HUD from the '99 to the '01 and it be only plug and play? No extra purchases required?
THanks.
THanks.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES!! Good luck with the hole in the 99 dash pad! You should have everything you need Z, and the Z to the 99, the hole will not be an issue.
BC
BC
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Tech 2 can not change the odometer. Takes a special interface module to do that. Not many people or shops have the required interface.
wow! the mileage is a function of the gage cluster? Never would've know that... Bill, I guess you're saying the hole is in a different place on the two? I was just going to switch out the dash on both... everything is black, and both cars have about 65k on the odo... actually on has 65 and the other I think is 68k..
... reread your post bill, I guess I read it wrong... the hole is correct?
The faces of my gages are messed up on the z anyway... I think someone glued on bezels and then took them off. It looks bad. I've been contemplating what to do.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Most newer IPC Clusters are HUD Enabled.
BC
thanks
