Replaced the EBCM, now car wont start
Old 04-03-2011, 04:20 PM
bsalie99
bsalie99's Avatar
Default Replaced the EBCM, now car wont start
I just replaced the EBCM in my 2002 Z06, The car ran befor I started the swap. I swaped it out with a new GM unit. I then got in and cleared all the codes. When I tried to start the car I just get some clicks and the PCM and TCS both show the No Comm code?
what went wrong?
Old 04-03-2011, 04:31 PM
lucky131969
lucky131969's Avatar
what went wrong?
What did you do exactly(include all steps). Post your codes.
Old 04-03-2011, 04:32 PM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
It's because they need to be sync up.
My boo boo thought it said "BCM" not EBCM" my bad.
Old 04-03-2011, 04:42 PM
bsalie99
bsalie99's Avatar
I will get the codes again later, What I did is as follows
The car is on a lift
I disconnected the MAF and removed the air bridge of the vairam intake
I disconnecter the upper coolant hose
I unplugged the 2 wire harnesses to the EBCM
I then removed the 6 screws
I seperated the EBCM from the pump
I reinstalled the new GM EBCM
reinstalled the 6 screws
I reattatched the 2 wire harnesses
then the upper coolant hose
then the air bridge and MAF
I then cleared all the codes in the car
I tried to start the car and it turned over 1 time then click
The car now says PCM no comm, TCS no comm when I pull the codes
I then unbolted the grounds just above the EBCM and cleaned them and reattatched them, Still get the No Comm errors and just clicks whan the key is turned
I tried to check Batt volts and got 12.02, but my meter is not trustworthy.
I then tried to start it again and no luck , and now the dash says low voltage
Old 04-03-2011, 04:47 PM
dougbfresh
dougbfresh's Avatar
Disconnect the EBCM just to rule it out-should not have anything directly to do with starting since the car can run without the module installed.
Old 04-03-2011, 04:51 PM
lucky131969
check your battery cables for security. Try a jump start, or put it on the charger.
Old 04-03-2011, 04:53 PM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Give that a shot -
Plus are you sure GM got you the correct part number for you year Vette?
There are many, especially if yours has AH and the one you purchased does not and visa versa.
Do the numbers match up on the two? new one and old one?
Let us know the numbers if possible.
Thanks,Matt
Old 04-03-2011, 05:08 PM
bsalie99
bsalie99's Avatar
The EBCM match exactly and are what the GM computer says goes with my VIN
I may try a battery swap
Originally Posted by madmatt9471
Give that a shot -
Thanks,Matt
Old 04-03-2011, 11:18 PM
Redeasysport
Redeasysport's Avatar
St. Jude Donor '05-'06
Battery
Old 04-03-2011, 11:24 PM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree,, disconnect the new EBTCM. ry cables are properly torqued in place. Make sure that the batte Then clear ALL the DTCs and try to start it. If it start doesn't start, read and post the DTCs. If you see NO COMS, open BOTH doors and shake the crap out of the accordion tubes and see if that changes things.
BC
Old 04-04-2011, 02:00 PM
bsalie99
bsalie99's Avatar
Dropped in a new red top opti battery and cleaned up the batt cable connections and it started on the 1st crank
so one problem solved, but I still get No Comms to the ABS code
Do I need to go to the dealer and have them flash it with a tech II?
Old 04-04-2011, 02:05 PM
lucky131969
No specific codes....or just no comm? You need to check for 12 volts and ground to the connector. If good, swap in the old EBCM, and see if you get the same result.
Old 04-04-2011, 02:09 PM
Redeasysport
Old 04-04-2011, 05:24 PM
madmatt9471
Dude check the fuses under the panel in the engine compartment!
I had one pop and it did the same thing - there will be a MAXI fuse and a smaller one so check "BOTH" - my smaller one is the one that popped! Replace it and perfect -
don't know why it did it nor has it done it again.
Thanks,Matt
Old 04-04-2011, 06:08 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EBTCM is a plug and play. No dealer requierd. I agree, FUSES, and the ground. Please read and post the codes with the IGNITION ON engine running. Clear ALL the DTCs and see if anything returns.
Old 04-04-2011, 11:01 PM
bsalie99
bsalie99's Avatar
Just checked the underhood fuses, all were good. I am worried that it is a harness issue, and that could cost me big
Old 04-04-2011, 11:02 PM
bsalie99
bsalie99's Avatar
codes with or without enging running?
To Replaced the EBCM, now car wont start
Old 04-04-2011, 11:21 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Time to break out the meter and get some critical voltage readings.. You have to PROVE that you have the correct voltages / and ground paths. Just because the fuses are good, doesn't mean that voltage is there.
BC
Old 04-04-2011, 11:23 PM
lucky131969
How exactly did you go about determining, that the EBCM was bad in the first place?
Old 04-04-2011, 11:32 PM
bsalie99
bsalie99's Avatar
I pulled the codes when i got the car and got
P1571
C1248
C1254
U1040
and a code for the outside air temp B0333
Brandon at ABSfixer said it was the EBCM that was fried and that he could not fix those codes
So I got a New EBCM from a dealer swaped it in and now get no comms
Quick Reply: Replaced the EBCM, now car wont start
