Replaced the EBCM, now car wont start
I pulled the codes when i got the car and got
P1571
C1248
C1254
U1040
and a code for the outside air temp B0333
Brandon at ABSfixer said it was the EBCM that was fried and that he could not fix those codes
So I got a New EBCM from a dealer swaped it in and now get no comms
P1571
C1248
C1254
U1040
P1571
C1248
C1254
U1040
P1571
C1248
C1254
U1040
Can you swap it back in and see if it gives you "NO COMM" for the old one as well?
That would also help as a test! But like Bill said you now need to check the actual power supply wires to see if you have "ACTUAL" voltage!
Thanks,Matt
need to check these!
It is best to install it like you would if it is new and you are ready to drive - one ground source comes from the ABS unit itself!
Thanks,Matt
Thanks,Matt
#33
I am headed off to Hawaii for 2 weeks, then I will have to dive back into this issue. I have not had time to do the voltage checks with all the last minute stuff for the trip
Thanks for the help, I will revive this when I return
