03 Z06 Overheating
Old 04-02-2011, 06:18 PM
02-C5
02-C5's Avatar
Default 03 Z06 Overheating
I know that there are many threads on this and believe me I have read them all in hopes I would not have to post...but here it goes.
2003 Z06, 25k miles air intake in the only mod.
This main issue is that the car overheats, 250-260 indicated at idle. The fans both come on but do nothing to stop the car from getting this hot.
I figured it was air in the system and went through that procedure with no luck. Read some more posts and figured in must be the water pump.
Installed a new water pump and stock thermostat today. Followed the refill procedure and the car seemed to be acting better. When both fans came on at 234* the temperature went down to 220 or so. I was happy and figured it was solved. I took it for a short drive and after a few miles it starting getting hot, even at cruising speeds. Pulled into a parking lot and it pegged out again at idle. Finally limped it home and here we are. There are no obstructions in the front of the car and all front air dam pieces are intact. The oil seems nice and clear and the coolant did not appear tainted either. WHAT ELSE IM I MISSING?
One more thing. The top radiator hose always seems to be under pressure while the lower hose that connects to the thermostat housing is not and appears to be flowing water.
Old 04-02-2011, 06:41 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Clean the radiator air intake system. Look up under the front bumper in the air intake sys and remove any trash, dirt, crap in the intake.
Pull off the air bridge and remove the plastic cover that cover the radiator and AC Condenser Coil. Theres a 1" space between the two and i well known to be FULL of CRAP.
Use a garden hose on full strength stream and BACK FLUSH the radiator. You will be amazed at the sand and dirt that comes out.
BC
Old 04-02-2011, 07:19 PM
02-C5
02-C5's Avatar
I did clean in front of the AC condenser and looked for any debris I could find and found very little. I will spray the radiator and condenser tomorrow.
I did notice that when the upper hose is not pressurized and flowing water the temps stay fairly regulated. Once that hose stops flowing and becomes pressurized it overheats. Can someone explain this?
Old 04-02-2011, 07:24 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
See below
Old 04-02-2011, 07:35 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Pressure is GOOD! Poor air flow and POOR coolant flow is BAD.... If it were me,,, I would reverse flush the radiator air path and see if that help.
If not, disassemble the cooling system... Remove the radiator, clean everything. Carefully examine the internal coolant passages in the radiator.. They should be SPOTLESS Clean. If there obstructed with CRUD,, that may be your issue..
While its apart, install a 180 deg T stat
BC
Old 04-02-2011, 07:38 PM
02-C5
02-C5's Avatar
Has anyone who has had this problem found it to be the radiator?
Old 04-03-2011, 09:52 AM
02-C5
02-C5's Avatar
Ttt
Old 04-03-2011, 10:22 AM
81c3
81c3's Avatar
Just so were clear.... when you say the hose has pressure, you dont mean a vacuum conditon right? Ive seen the upper hoses sqeeze shut on some systems...
Old 04-03-2011, 02:25 PM
02-C5
02-C5's Avatar
Hose is not collapsed.
Old 04-03-2011, 05:48 PM
02-C5
02-C5's Avatar
Update: Engine cold
Disconnected one side of the metal coolant crossover that runs from the corner of the heads in the front of the motor. No coolant came out, but as I filled the surge tank I finally got some seepage. I was advised that air can get trapped in that area of the heads and cause issues. I also cleaned the condenser and radiator the best I could with water and a vacuum. Appears to have solved some or most of the problem. Cruising speed temp w/o AC is 196-198, w/AC 201. Not much stop and go traffic but I did let it idle in the drive and it got to 225 or so, turned on the AC and the temps go down to 210 or so. Not flying the "Mission Accomplished" banner yet but looking better.
Old 04-03-2011, 08:48 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Probably needed to burb the system to get the air out.
Hopefully that's all it was.
To 03 Z06 Overheating
Quick Reply: 03 Z06 Overheating
