Abs/traction lights stayon
Cruising
Had a repair shop test ,while running ,diagnosed as needing replacement ($900+) for part + labor (1600 total) has been a recent interrmitting (light) problem, told it is a common GM problem , 48K mi 2003 .not up North now (Mass) but Fla ,Sfe to drive home in April? . :Thanx for input Cliff
Everything you need is on the DIC. This is the set of buttons on the right side of cluster.
Push and hold the options, then push the top (fuel) four times, it will bring up a monitor system that you can go through. Write down everything, and bring it back here. Since you've never done this before, don't be afraid to do it a few times. Its a great feature of this car. When you get comfortable with it, go ahead and reset everything, and see what comes back. Also, when you get the codes, note if they have a "H" or "C", (history or current) after them.
