High flow cats and passing CA smog?
Old 03-09-2011, 02:01 PM
memphis_vette
memphis_vette's Avatar
Default High flow cats and passing CA smog?
hey guys i did a search already and did not find too much on this subject. is there any way i can pass CA smog with HF cats?
Old 03-09-2011, 02:31 PM
dougbfresh
dougbfresh's Avatar
Why chance it for the few HP you might get?
Old 03-09-2011, 02:56 PM
BitViper
BitViper's Avatar
I have no direct knowledge but.. Ive see that they will pass the sniffer test.. but NOT the visual
Old 03-09-2011, 03:17 PM
tlove32
tlove32's Avatar
They'll pass
Old 03-09-2011, 03:59 PM
memphis_vette
ok would i have to get my car tuned to make them pass or will a stock tune work?
Old 03-09-2011, 04:48 PM
Bad97ta
Bad97ta's Avatar
correct
Old 03-09-2011, 05:28 PM
DaBoz
DaBoz's Avatar
All three of my vehicles have been smoged recently and not once did the tech pay attention to anything mechanical.
Hooked up to the computer, did the test as fast as possible and he was done.
Old 03-09-2011, 05:42 PM
Bad97ta
Bad97ta's Avatar
What mods do u have done to your exhaust
Old 03-09-2011, 05:49 PM
hattitude
hattitude's Avatar
While I have no doubt people pass SMOG everyday with high flow cats, the truth is, if the test is done correctly..... they will not pass the visual.
Being lucky enough to get an (ignorant/ lazy/ apathetic) inspector, knowing someone in the SMOG business, and/or paying someone in the SMOG business to get a car to pass SMOG is really not the same as telling someone they can pass.
I realize I'm splitting straws here, but I'd hate to have someone think they are legal and then fail and get tagged at a SMOG test.
FWIW..........
Old 03-09-2011, 06:26 PM
Bad97ta
Bad97ta's Avatar
[QUOTE=hattitude;1577010316]While I have no doubt people pass SMOG everyday with high flow cats, the truth is, if the test is done correctly..... they will not pass the visual.
FWIW..........
well said
Old 03-09-2011, 06:50 PM
memphis_vette
if you are talking to me then i have stock manifolds, stock cats, x-pipe, and flowmaster 80 series mufflers.
Old 03-10-2011, 03:02 AM
00Corvette
00Corvette's Avatar
I doubt they crawl under your car or put it on a lift..try and find a smog guy without a lift.
If you have stock manifolds...I'd say go for it.
You won't pass the visual if the tech does look underneath AND knows what the stock cats look like..I've yet to see a smog tech jack up a Vette to see if the cats are stock UNLESS you're running some crazy sounding motor
Old 03-10-2011, 05:26 PM
mountainbiker2
mountainbiker2's Avatar
I have a stock LS6 motor and the HF cats did not pass. They have many races on them. You probably will pass if there new.
Old 03-10-2011, 05:34 PM
chevylad
chevylad's Avatar
Cut an old cat in half and band clamp them around the high flow cats to the existing exhaust.
Old 03-11-2011, 09:54 AM
SueTaing
SueTaing's Avatar
did something simular on my evo except i welded mine on
Old 03-11-2011, 10:11 AM
imavettegirl
imavettegirl's Avatar
they all go on the dyno in california and it lifts for them to match pics on the computer screen.
Old 03-11-2011, 10:22 AM
dougbfresh
dougbfresh's Avatar
Sure is amazing the trouble people will go though for almost no gain.
To High flow cats and passing CA smog?
Old 03-11-2011, 11:20 AM
Bad97ta
Bad97ta's Avatar
my inspector guy used a crazy mirror and flashlight to look under my car. he also spent 5 minutes looking at the vararam. i cant stand california. ohh well
Old 03-11-2011, 08:56 PM
00Corvette
00Corvette's Avatar
No they don't.
I live here
as a matter of fact there isn't ONE dyno in the entire county Memphis and I live in. TONS of smog shops though
my guy just looked over to his buddy and said 'hey Murph..that stock??'
Old 03-11-2011, 09:03 PM
00Corvette
00Corvette's Avatar
And most have no idea what the stock cats look like..they all look so different. If they don't for example realize that you're supposed to have pre-cats on a 2000...which most wouldn't.
It really is a crap shoot though, the stock cats suck. I swapped mine just for a little more sound, had nothing to do with horsepower...that and the fact that the long tubes deleted the pre-cats so at the time I figured why not.
Keep in mind that I did my LT's 4 years ago..beginning of 2009 or 2010 SMOG laws either changed or they really cracked down. I think both.
It's hard to even BUY cats that aren't CARB approved now...it's even harder to get someone to weld them on for you unless you have a buddy.
If I would have known it would be this tough to smog my car years later, I would not have done the long tubes.
Now that I have them, I'm just really careful at smog time and make SURE that everything is as stock looking/sounding as possible..I'm very friendly, play dumb and always get a referral.
Quick Reply: High flow cats and passing CA smog?
