Rack and Pinion rebuild kit?
Old 02-24-2011, 12:05 PM
brrymnvette
brrymnvette's Avatar
Default Rack and Pinion rebuild kit?
Anyone know if there is a rebuild kit for the rack and pinion? I have a seal leaking and I'm not going to spend $400 for a rack if I can rebuild this one with new seals.
Old 02-24-2011, 03:56 PM
alextz
alextz's Avatar
Default steering rack rebuild
Zip corvettes will do a rebuild for $225 with core exchange.
IF you go to turnone, which is what I recommend, the guy is an ex GM steering engineer, he will remanufacture the rack with rack dyno testing, $250 for that.
Old 02-24-2011, 04:39 PM
lucky131969
lucky131969's Avatar
So you consider a steering rack "rebuilt", just changing the seals? Do you work for Autozone?
Old 02-24-2011, 05:08 PM
Cratecruncher
Cratecruncher's Avatar
Do you know exactly where it's leaking. Reason I ask is because I had a small but messy leak coming from the unit near the steering pinion. When I replaced my harmonic balancer the hydraulic lines had to be detached. The little neoprene o-rings were hard as a rock and triangle shaped. Buttoned it back together with fresh o-rings and no more leak! Of course, your results may vary.....
Old 02-24-2011, 07:27 PM
C5FORFUN2
C5FORFUN2's Avatar
Good tip, that's what mine is doing although not too bad yet.
Old 02-24-2011, 07:36 PM
brrymnvette
I consider it rebuilt when it's been rebuilt. But good try at being a smart ***.
Yeah, I know exactly where it's leaking. Had it on the rack at our shop already to pinpoint exactly where it was. So, it's either rebuild it or waste money to get a rebuilt one when I'm more than capable of doing it myself. But, that's a good tip though.
Old 09-03-2012, 03:51 PM
3dwaxmill
7th Gear
3dwaxmill's Avatar
Did you ever find a seal kit for your rack and pinion?
Old 09-04-2012, 09:10 AM
3boystoys
3boystoys's Avatar
Good time to swap the harmonic balancer out while the rack is out.
To Rack and Pinion rebuild kit?
Quick Reply: Rack and Pinion rebuild kit?
