C6 Z06 Brakes w/ Cray Scorpion Wheels?
Curious, will C6 Z06 Brakes or any other comparable (in cost) big brake kit fit 18/19 Cray Scorpion Wheels?
I fitted Hawk HPS to the stock calipers with drilled and slotted rotors and they work better than OEM on my Cray 18/19s.
If you have or can find a set of Crays put one on the front of a stock C5 brake set up and measure the distance from the outside of the stock caliper to the inside of the Cray's spokes. If you have 3/4" or more you are good to go. Any less than 3/4" will require spacers. All wheels will fit on the rear.
