2000 C5 Hardtop MAP Sensor Location
Old 02-12-2011, 11:43 AM
cgallagher78
Cruising
cgallagher78's Avatar
Default 2000 C5 Hardtop MAP Sensor Location
I am getting a code P0107 and feel that with over 100K miles, the MAP sensor has finally bit the dust.
I cant seem to locate it and the only picture I though I saw shows that it is attached to the back of the manifold (right next to the fire wall).
Is this correct and is there and easy way to replace?
Old 02-12-2011, 11:46 AM
corvettebob1
corvettebob1's Avatar
Yes, remove the intake to replace it.
Old 02-12-2011, 11:48 AM
cgallagher78
Cruising
Son of a b*tch...
Just called the chevy dealer and they even said it was located up front... just goes to show you
Old 02-13-2011, 10:51 AM
corvettebob1
Originally Posted by cgallagher78
Son of a b*tch...
Guess they didn't know the difference between the MAP sensor and MAF, that is untill you ask them to install it!
Old 02-13-2011, 12:35 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here ya go:
Sensor just pops out of that fitting.
BC
Old 02-13-2011, 01:47 PM
cgallagher78
Cruising
Bill,
Great picture but is that the back of the manifold after it has been removed? If not, where exactly is that?
If it is the back of the manifold, I am probably going to punt to my local guy to fix for me rather than trying to do a weekend project and most likely do more damage in the process.
Old 02-13-2011, 04:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP! Back of the intake. Heres what the top of the engine looks like with it removed:
BC
The following 2 users liked this post by Bill Curlee:
jpbikes (04-17-2022), Ulianokr (07-06-2017)
Old 02-13-2011, 06:37 PM
cgallagher78
Cruising
Thanks for the pic's and info and you just cemented my decision to have my local guy do this. Out of my pay grade and time commitment.
Old 02-13-2011, 06:47 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
MAKE SURE that who ever does the repair just doesn't slide the manifold forward, replace the sensor and slide it back. If you look at the picture of the valley, you will see all kinds of sand and dirt.
The little Vacuum line is also critical to be properly connected. Its tough. If I were you I would purchase a nylon vacuum line repair kit from AutoZone / Advance and give it to the mechanic to extend the line. If its not connected properly, the HVAC Vents will not change properly.
BC
Old 02-13-2011, 06:52 PM
cgallagher78
Cruising
Thanks for the heads up on this and I will be sure to print off what you just said.
Old 02-13-2011, 07:43 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Likely looked up a picture of a C6. That's where it's located on LS2/3/7.
Old 07-06-2017, 10:48 AM
Ulianokr
Ulianokr's Avatar
Default I couldn't own a vette without sites like these
[QUOTE=Bill Curlee;1576783098]YEP! Back of the intake. Heres what the top of the engine looks like with it removed:
In the past few months I've had to replace my MAP sensor and then the Oil Pressure sensor... Researched topics via the site and got GREAT info and procedures.. Job done once and done right.. but I could never have even thought about doing myself...Thank you BILL and everyone else that has offered advice
To 2000 C5 Hardtop MAP Sensor Location
Quick Reply: 2000 C5 Hardtop MAP Sensor Location
