Old 02-23-2015, 04:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tires and Wheels
Print Wikipost
Can non-run flat tires be used for C5?
Old 03-29-2011, 09:50 PM
migg48
5th Gear
migg48's Avatar
I have a 2004 with run flats on it. I'm having them removed and putting Potenzas on. I look at it this way: Run flats are loud, hard and don't handle very well. If I were driving from, say, Phoenix to El Centro all the time...run flats would be a good idea. But I drive around town, to the golf course, etc. I have AAA and tire sealant. Who needs run flats?
Old 03-29-2011, 11:16 PM
SG Lou
SG Lou's Avatar
Old 03-30-2011, 12:00 AM
VettefanC5
VettefanC5's Avatar
I'm running Kumho's on my '01 Convertible. The ride is much softer than run flats. AND, Paid about $140 each. Thats under $600 for the set. Cha ching.
Old 03-30-2011, 02:52 PM
Oldvetter
Oldvetter's Avatar
Default Sealant may not work
If you leave your TPS (Tire Pressure Sensors) in your wheels (strongly recommended, because they can warn you of air leak due to a nail in the tire) be aware that you may not be able to use a tire sealant, it may not flow past the TPS.
Also, you will probably need a jack to plug the tire. Ever try getting under a car with only 2 inches ground clearance to plug a tire? The jack must fit under 2-3 inches due to flat tire.
Old 03-30-2011, 03:19 PM
worldtraveler
worldtraveler's Avatar
Location: Proud dad of 2 responsible adults and 1 fallen warrior txtx
Based on your type of driving, whywould you need to pay the premium for Z rated tires?
Old 03-30-2011, 04:49 PM
guido7834
guido7834's Avatar
Me too! And run flats are crap.
Old 03-30-2011, 04:57 PM
MCVetteLs6
MCVetteLs6's Avatar
weather you get run flats or non... dont apy what they are telling you.. that price is rediculous...
i bought the michelin run flats a/s plus for like 1100$ and they are amazing tires... alot of people use them...
you should DEF be able to get non run flats for cheaper than that!
Old 03-30-2011, 05:54 PM
k24556
Support Corvetteforum!
k24556's Avatar
Default plugs
The tire experts say not to use the rope plugs that most folk carry on high speed tires. See the attachment, the proper repair is the patch/plug. I've used the rope plugs on ordinary tires and on truck tires in an emergency, but wouldn't on a Z rated tire. Also a Michelin tech expert told us at a seminar that the rope plgs are a total no-no on runflats.
File Type: pdf
Old 03-30-2011, 06:09 PM
Razzputon
Razzputon's Avatar
Originally Posted by rfh928
Might be worth me driving the Vette 2 hours south across the border to Buffalo, and getting the tires swapped there
Thanks!
Robert
Any excuse for a road trip is a good excuse.
Old 03-30-2011, 06:10 PM
65convt
65convt's Avatar
I got rid of the Goodyear runflats for Hancook Ventus V-12 non runflats. $770.00 mounted, balanced and out the door.
I Love the way they ride and handle. Also very quiet.
Old 03-30-2011, 06:26 PM
Razzputon
Razzputon's Avatar
I have a couple k miles left on my run-flats and am about to get them changed out to non run-flats. I already got my flat kit, Slime (sensor friendly) and 12v compressor. If I cant fix it with that then it's a AAA call. Reading this thread I had a couple of questions:
Originally Posted by ALLEGRO
Get a good kit and be sure you get some needle-nosed plyers as well.
Why do you need needle-nosed plyers? =)
Originally Posted by 20mercury
Good advice above on using a torque wrench to tighten the lug nuts! I also took my tires off and put them back on after the tire shop trip myself!
Is this a common practice? I haven't read anything about doing this on any other thread. Is there a reason behind it?
Thanks!
Old 03-30-2011, 06:31 PM
lucky131969
lucky131969's Avatar
...or is it common sense.....?
On a serious note, it is very easy to crack(or deform) aluminum or magnesium rims, by overtorquing them.
Old 03-30-2011, 06:40 PM
  #33
dbaker
dbaker's Avatar
Vred's on my 02Z.(2)275/35/18 & (2)295/30/19 were $720 + $80 for ship from Wcoast to Ecoast.
Love'em
AAA,cell phone & Slime Quick Spair for me.
\db2
carolina
Old 03-30-2011, 06:43 PM
  #34
Razzputon
Razzputon's Avatar
yeah. I'm a Vette newb. I just bought the most beautiful 2004 Vert a few weeks ago and am learning everything I can about them. I have had a poster of my favorite vette in my garage since 2000. Bought one to match the poster. =) *points to his avatar*
Old 03-30-2011, 09:29 PM
  #35
vette.mix
vette.mix's Avatar
Old 03-30-2011, 09:41 PM
  #36
jrose7004
jrose7004's Avatar
Received 1,675 Likes on 1,298 Posts
I've had both Runflats and non Runflats on my C5. No problem running either.
Old 03-30-2011, 10:14 PM
  #37
Carcass
Carcass's Avatar
Rope plugs will get you home,or to a tire repair shop,no matter what kind of tire you use them on....
To Can non-run flat tires be used for C5?
Old 03-31-2013, 06:13 AM
  #38
lhoffman118
3rd Gear
lhoffman118's Avatar
Default Bridgestone's Tire
I run Bridgestone tires on my 1999 C5 Hard Top. They handle better, are quiet, and offer a very good ride. I have another 1999 C5 Hard Top with the run flats and they are a rough ride and noisy. I recommend changing to a traditional high performance tire once your run flats are worn out. Like some of the other posters said, you can get an AAA membership or insurance coverage to assist you if you get a flat on the road.
Old 04-01-2013, 06:21 AM
  #39
SG Lou
SG Lou's Avatar
Originally Posted by Carcass
Non-runflats work just fine on the C5 - they're quieter,and the ride will improve by 100%
My General UHP's were $525.00 delivered,plus $75.00 mounting and balancing,but you can spend a lot more if you want to.
Get a small 12v compressor,a flashlight, and a plug kit to stow in one of the rear compartments in case of emergency,and you should be all set.
to all of the above. Luv the Generals !
Old 04-01-2013, 08:49 AM
  #40
DARRYLZO6
DARRYLZO6's Avatar
Other than the so-called piece of mind, it doesnt make any sense to spend that kind of money for tires on an essentially 10+ year old car. Ive rode in vettes with runflats and in all honesty, i dont know how anyone can stand it. Hard ride, noisy, b.s. grip in wet/cold roads, and the replacement costs for most brands is unrealistic. For instance you can get a set of Bridgestone Potenzas for as low as $600 online in stock sizes. I have the Potenza RE 760 Sports and Im very happy with the performance and price. Also have AAA as well as OnStar for my piece of mind. From an economic/ comfort standpoint,personally spending that kind of cash is nuts!!
Quick Reply: Can non-run flat tires be used for C5?
