EBC Module
EBC Module
I own an '01 C5 i'm getting notices on the dash that active handling, traction control and abs need servicing took it to the dealership had them pull the codes, and was told the EBCM was bad and needed to be replaced was quoted $1700.00! I found one on the net, its original GM part still in original unopened container with correct part #12216561 for better than half what the dealer wants .... QUESTION: what am i getting into? i was told its going to need to be programmed, any help with this would be greatly appreciated.
Location: Mobile,Alabama When someone tells me they've always wanted a Corvette,I say...GETUONE.
I had the same problem with my 2002. The local Chevy dealer wanted $1800.00 to replace it. I bought a new one from the Parts Ladi in Destin,FL. for $700.00 and installed it myself. It's very easy to replace, only six screws hold it on. I did not have to reprogram it. I have not had any lights or codes since.
The first thing you need to pull the codes yourself using the link below. Then post up the codes here so we can see what the problem my be.
http://web.archive.org/web/200306051...D=26&TopicID=1
There are only certain codes and problems that he can repair. I sent my original EBCM to him and he could not fix it. It would be worth it to contact him with your codes before buying a new one to see if he can fix it.
Wow thanks for the response! That just got Corvette forum a new subscriber. I come from more of a late 60's early 70's mc "old school" im going to have to relearn a few things.
To the point at hand i ran diag display mode and pulled 25 codes all but 1 ended in "H" the code that didn't was from 28-TCS C1214 H C help any?
This is my 1st vette bought it to "play" with but before that i want to make sure the electronics are functioning
This is the EXACT error absfixer repairs-bad relay inside the ECBM. Check out his site, he has instructions on how to remove the module and ship it to him-you can drive the car while it's out-only takes a couple of days to turn it around and the repair in less than $200 and guaranteed for life.
This thread is 6 1/2 years old.
Why don't you start a new thread and state what the problem is, along with any trouble codes before you buy a used EBTCM ( you can't buy a new one). I think you mentioned in another thread that you couldn't shut off the traction control. That could be something as simple as a bad ground.
