Scorpion Race Series Roller Rocker Arms [GM LS1, LS6, LS2, L92, LS3 & LS9]
All Scorpion Rockers Feature:
Needle Bearing Fulcrum and Roller Tip, Centerless Ground Trunnion, Centerless Ground Pin & Roller, Burr-Free Thru Hole in Trunnion, Large Machined Seat, Thick Walled Adjusting Nut, Pedestals Machined from Solid Steel, Black Oxide Coated Steel Parts, & 100% CNC Machined. Other benefits include:
• Available in all ratios
• Lightweight for maximum performance
• Easily handle .950” lift and 950 lbs of open spring pressure
• Clear 1.625” valve springs
• Micropolished surfaces finish for maximum durability
• Anodized for additional protection and aesthetics
• Exclusive LIFETIME WARRANTY - all series
• Available ratios 1.7-1.8 Chevy LS engines
• The only ‘No Machining Required’ kit in production
• No changing pushrods, guide plates, rocker studs
• No need for valve cover spacers
Scorpion Race Series Roller Rocker Arms, 1.7:1 (GM L92, LS3 & LS9) [SCP1062] - $551.50 SHIPPED
Chevy V-8 L92-LS9-LS3 - Non-adjustable. No machining required.
Scorpion Race Series Roller Rocker Arms, 1.7:1 (GM LS1, LS6, LS2 & LQ9) [SCP1098] - $372.26 SHIPPED
Chevy V-8 LS1-LS2-LS6-LS364/400-LQ9 - Non-adjustable. No machining required.
PLEASE EMAIL US FOR PAYMENT INFO. THANKS.
CURRENT DISCOUNT COUPON CODES
If you have any questions, please e-mail us as we do not frequent CORVETTE FORUM and may not answer any posts in a timely manner. Thank you.
So the SCP1098 is a non-adjustable drop in replacement for LS1/6 applications using stock length pushrods and no valve cover spacers? I have an LS6 with a .644 lift cam and otherwise stock valvetrain (upgraded springs only) and I'm considering an upgrade to roller tip rockers. I don't want to use rocker cover spacers or change pushrod lengths.
These will drop into the otherwise stock heads using the OEM rocker mounts/studs?
Just want to clarify as the listed specs for these rockers seem to cover ALL of the rockers including those that are not listed for sale here.
Thanks!
Thanks!
I have the same question since the needle issue I am considering the rocker change out.
Will these drop right in and bolt right up with doing nothing else in a stock 98 ls1 motor in a corvette??
