Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-17-2011, 08:06 PM   #1
TexasSilverVette
Junior Member
Default Turn Key and Nothing Happens
I have had a problem with my 2002 C5 for months. Usually when hot, I turn the key and nothing happens. I could not replicate it for the dealer. The first dealer could not figure out the problem. The second dealer told me it was the ignition and replaced for for nearly a grand. Today, the same thing happened. Brand new battery. This, combined with the fuel indicator issue (indicating an empty tank at random times) that I have had for over a year, and which the first dealer attempted to fix FOUR times, has caused me to believe that there is not a competent Chevy dealer in Dallas.
TexasSilverVette is offline   Reply With Quote
Old 01-17-2011, 08:11 PM   #2
k24556
CF Senior Member
Support Corvetteforum!
auto or manual? My 2000 was a manual and i had that situation. If I depressed the clutch a coupe of times it would start, figured it was the switch that tells the circuit the clutch is all the way in.
k24556 is offline   Reply With Quote
Old 01-17-2011, 08:15 PM   #3
Silverbullet00
CF Senior Member
Silverbullet00's Avatar
Location: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Quote:
ALL CORVETTE DEALERS MOSTLY SUCK!
That being said, the brains on this forum need more info from you to be able to help you. There is more knowledge to be had here than anywhere else.
The brains would need:
DIC codes for starters, and a more detailed description of "nothing happens". For example, not even a click when you bump the key?
My first guess is a ground problem that has no connection to engine temp,,,,,but now you got me guessing....and I am NOT a CF brain.
CALLING ALL BRAINS!
__________________
Non Member of the Non Club Club of Oklahoma.
Silverbullet00 is offline   Reply With Quote
Old 01-17-2011, 09:24 PM   #4
8VETTE7
CF Senior Member
8VETTE7's Avatar
Pull and post the codes:
http://www.c5forum.com/ayc/dtcdic.php
Codes are 5 positions long. First is an alpha character, the next 4 are numeric. The code will be followed by an H, or a C or an HC. Post the entire sequence for each code that you have.
When you turn the key and nothing happens, what is the status of the security light? Off? On?? Blinking???
8VETTE7 is offline   Reply With Quote
Old 01-17-2011, 10:59 PM   #5
redrckt97
CF Senior Member
redrckt97's Avatar
when you say "nothing happens" does that mean it won't crank?...does the dash etc light up? ...power on but not cranking when hot can be a faulty starter or solenoid.
redrckt97 is offline   Reply With Quote
Old 01-18-2011, 07:19 AM   #6
SharkByte
CF Senior Member
SharkByte's Avatar
My '04 recently developed what sounds like the same problem. Twist the key and the cluster runs through the self check but the starter doesn't even click. It literally runs the instrument cluster check and does nothing. You twist the key back and try it again and it starts right up like nothing was wrong. Usually it starts on the first try, sometimes it takes 2-3 twists, sometimes it takes 5... The C5 tech guru's said it was the ignition so I'm planning on pulling it out and rebuilding it this weekend to see if that fixes it. If thats not it I'll park the car for a few months when I go to Afghanistan at the end of the month and trade it in on a C6 when I get home...
SharkByte is offline   Reply With Quote
Old 01-18-2011, 08:50 AM   #7
dgrant3830
Wounded Warrior Escort '11
dgrant3830's Avatar
Send a message via AIM to dgrant3830 Send a message via Yahoo to dgrant3830
Quote:
Your issue does indeed sound like the ignition switch. The OP's issue could easily be a clutch switch or security issue or the solenoid itself. Codes will help to determine which.
dgrant3830 is offline   Reply With Quote
Old 01-18-2011, 09:37 AM   #8
SharkByte
CF Senior Member
SharkByte's Avatar
Quote:
Mine is not throwing any codes at all... That was the first thing I checked
Old 01-18-2011, 09:53 AM   #9
8VETTE7
CF Senior Member
8VETTE7's Avatar
If there are no codes then I would strongly suspect the ignition switch has some burned contacts and is in need of the Bill Curlee Ignition Switch Repair:
http://forums.corvetteforum.com/c5-t...ch-repair.html
Old 01-18-2011, 11:10 AM   #10
dgrant3830
dgrant3830's Avatar
Yes, I agree. Even if the security was causing an issue, there would be a code. Now lastly, do you hear a click in the passenger footwell and/or do you hear the starter solenoid click loudly? If the TDR relay is actuating but the voltage from it to the solenoid isn't getting there, then a new relay is in order. But if the TDR isn't getting activated, its either the security or the ignition switch...clutch switch if equipped, neutral switch for autos...
Old 01-18-2011, 02:11 PM   #11
SharkByte
CF Senior Member
SharkByte's Avatar
Thats the DIY guide I'm going to be following Just have to have a few hours I can be without the car to rip it apart and fix it...
Old 01-18-2011, 02:20 PM   #12
mmartinez
CF Senior Member
mmartinez's Avatar
I would suspect the starter/solenoid because you mentioned that it does not want to start after it has been has warmed up. My first suggestion is to measure the switch terminal on the solenoid and check for 12 volts when it does not want to start, if 12 volts is present then its either your starter/solenoid or bad grounds. If 12 volts is not there then its something upstream, TDR, neutral safety switch, or bad contacts on ignition switch. Good Luck.
mmartinez is offline   Reply With Quote
Reload this Page Turn Key and Nothing Happens
Tags
1990, 2000, c5, corvette, ignition, key, manual, pull, replace, starts, startuntil, tdrrelay, turn, turns, wont, z28, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
