Seat Memory Failure - SCM and BCM Sync Needed?
Having the same problem with the memory on the drivers seat, with the code B2605, but noticed that when I touch or jiggle the electrical hook up under the seat the seat moves and also can here one of the motors running. Looks like maybe a broken ground wire, or bad connection. Will pull the seat out in the spring and check it all out.
kedvesh (11-11-2020)
Thanks for chiming in! When time (and $$$) allows, I think I’m going to have to pull the seat (again) and have a qualified person check all the connections. This (and the steering column telescopic position function)—essentially the easy entry option—have been a pain in my behind for more than a few years.
Good luck with your resolution efforts! 👍
Overall, the seat function/position as it interfaces with the memory as well as the steering column position and telescopic function (a long way of saying the "easy entry" function of the seat and steering column) remain very much non-cooperative. Maybe I'll get to work on this as a winter project.
Good luck on your seat/memory issues!
