How is the interior plastic rails/mouldings remvoved are they just pull of or clips also the other speaker moulding. Thanks for any help
Yes, they are almost all held on by clips. It helps to use one of those plastic trim removal tools to get them off. Gently lift on each one until you sort of figure out where the clip(s) are then use the tool to pop it off.
