Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-13-2010, 11:30 PM   #1
CHRIS COVE
CF Member
Default Wheel bearings or just road noise
I'm experiencing what I think is a lot of road noise from the back end and can't hold a conversation without raising my voice. Can the sound of bad wheel bearings be mistaken for road noise or do bad bearing make a different sound. Also I plan on getting rid of the runflats asap.
CHRIS COVE is offline   Reply With Quote
Old 12-13-2010, 11:41 PM   #2
jrose7004
CF Senior Member
jrose7004's Avatar
Jim Rose Jim Rhttp://www.linkedin.com/profile/view?id=89789687&trk=hb_tab_pro_topose
Do you have old Good Year runflat tires?
jrose7004 is offline   Reply With Quote
Old 12-13-2010, 11:44 PM   #3
Silverbullet00
CF Senior Member
Silverbullet00's Avatar
Location: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Quote:
WAY MORE info needed, pavement, miles on car, hearing aids turned up to much, stereo down to low,,,get my drift.
Chances are you won't hear wheel bearings at the back and would have to be real good to hear them in the front.
I have nearly 79K on the clock, just did major brake work last weekend,,,bearings we dead silent at all four corners in a quiet garage!
Silverbullet00 is offline   Reply With Quote
Old 12-13-2010, 11:50 PM   #4
CHRIS COVE
CF Member
I have Michelin Pilot Sports. Prior to that Goodyear and Kumho and never noticed a problem with those. It's loudest around 68mph. High pitch whine driving down the freeway. I have 105,000 miles on the car. No need for hearing aids yet, although this may lead to needing them.
Old 12-13-2010, 11:52 PM   #5
CHRIS COVE
CF Member
Only 8,000 miles on the tires
Old 12-14-2010, 12:34 AM   #6
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
One good common sense test for wheel bearings is the wiggle test. Jack up the car and Grab the wheel at the NORTH/SOUTH & EAST/WEST (000/180 & 090/270) deg quadrants and push pull the wheel. With a GOOD bearing, the deflection should be very little if any. The more you see/feel, the worse the bearing is. If you see a LOT, a new bearing assy is needed.
FRONT BRG ASSY
Click the image to open in full size.
REAR BRG ASSY
BC
Bill Curlee is offline   Reply With Quote
Old 12-14-2010, 12:55 AM   #7
CHRIS COVE
CF Member
Good point I'll try that. Damn the bearing assembly doesn't look cheep.
Old 12-14-2010, 01:13 AM   #8
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
PM me if you have questions.
BC
Old 12-14-2010, 01:36 AM   #9
bmfrc
CF Senior Member
No, they are not cheap.... I would like to find a good deal on a pair of rears to swap mine!!! If it is the rears, they are def. loud in the car, kinda hard to talk over!!
bmfrc is offline   Reply With Quote
Old 12-14-2010, 02:58 AM   #10
Bill Dearborn
Bill Dearborn's Avatar
I had the same type of noise on my 97. There was a lot of noise from the rear. When I put Firestone Run Flats on the car I thought it was supposed to get quieter but it didn't so I took it in to have it checked. Turned out I had to have all 4 wheel bearings replaced (bless GMPP). The noisiest bearing was the right front. The mechanic told me he couldn't tell the bearing was bad until he removed it from the car and turned it in his hands and felt how rough it was.
Bill
Bill Dearborn is offline   Reply With Quote
Old 12-14-2010, 07:22 AM   #11
AU N EGL
CF Senior Member
AU N EGL's Avatar
High pitch whine? the Passenger? Just kidding
Check the bearings as Bill mentions and or
could be the diff fluid needs to be changed.
AU N EGL is offline   Reply With Quote
Old 12-14-2010, 10:55 AM   #12
CHRIS COVE
CF Member
Thanks everyone. I'm bringing it in to get the bearings/Diff checked out. $$$ I can see it coming!
Old 12-14-2010, 11:13 AM   #13
runner140*
CF Senior Member
runner140*'s Avatar
This is something you can do on a week-end. Remember, stay away form "stealerShips", if you can.
runner140* is offline   Reply With Quote
Old 12-16-2010, 09:17 PM   #14
CHRIS COVE
CF Member
UPDATE: It was my right rear wheel bearing. Got it replaced and the interior is quit now. Besides the load noise my dashboard, doors and roof where rattling so bad I was going crazy.
Thanks for the replies!!
Old 12-16-2010, 09:18 PM   #15
CHRIS COVE
CF Member
$600.00 Dealer repair. Not too bad. Dealer bearing is $283.00 alone.
Reload this Page Wheel bearings or just road noise
Tags
2005, bad, bearing, bearings, c5, c6, corvette, create, noise, road, wheel, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
