What is included in an LS1 "Long-Block"?
Old 12-15-2010, 10:58 PM
Choreo
Support Corvetteforum!
Choreo's Avatar
Default What is included in an LS1 "Long-Block"?
Just curious... what does GM include?
Old 12-15-2010, 11:53 PM
00Corvette
00Corvette's Avatar
I would assume everything up to the heads..without heads of course.
block, crank, rods, main caps, rings, bearings, balancer, flexplate, pistons, oil pump and pickup, timing cover and seal, freeze plugs(oil pan maybe)...assembled. a cam is probably a few hundred extra
Old 12-16-2010, 01:53 AM
099blancoss
Former Vendor
99blancoss's Avatar
St. Jude Donor '10-'11-'12
gm long block is usually a crate style engine and will have everything
"long blocks" as opposed to shortblocks are usually the shortblock plus the heads and valvetrain
Old 12-16-2010, 02:01 AM
Choreo
Choreo's Avatar
...so it would include a cam?
Old 12-16-2010, 02:03 AM
099blancoss
Former Vendor
99blancoss's Avatar
yes a cam, timing set up, engine covers, the whole nie yards if it was a gm crate engine
Old 12-16-2010, 09:06 AM
thatreallyslowc5
thatreallyslowc5's Avatar
Minus all the sensors, intake manifold, throttle body, etc.
I just bought an LS6 long block from gm.
Old 12-16-2010, 09:47 AM
rebelheart
rebelheart's Avatar
A short block doesnt include heads,a long block does.Mostly a long block requires intake and exhaust manifolds and accessories to be swapped on,electronics, fuel rail etc.
Old 12-16-2010, 08:49 PM
Choreo
Choreo's Avatar
Thanks for all the replies... that answers my questions.
To What is included in an LS1 "Long-Block"?
Quick Reply: What is included in an LS1 "Long-Block"?
