Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-01-2010, 04:58 PM   #1
luc719
CF Member
luc719's Avatar
Default sodium filled valves???
I just bought a set of 243 heads and found out after they do not have the sodium filled valves. What is the difference between normal and sodium filled? and should i go buy them before i put the heads on?
NOTE: this car is my weekend car, not a track car
luc719 is offline   Reply With Quote
Old 12-01-2010, 05:07 PM   #2
dougbfresh
CF Senior Member
Sodium filled valves are very light-the center is hollowed out for running high rev's. Not really needed for normal/casual driving.
dougbfresh is offline   Reply With Quote
Old 12-01-2010, 05:23 PM   #3
Toxiclemonade
CF Senior Member
are 243 heads not the stock heads that come on a standard c5?
Toxiclemonade is offline   Reply With Quote
Old 12-01-2010, 05:32 PM   #4
manley845
CF Senior Member
manley845's Avatar
Quote:
241 heads were on base models. The Z06 received 243 heads.
The LS2 uses 243 heads with non-hollowed valves. Gotta be careful what the heads came off of, if you want the hollow valves.
The Hollow valves are about 90gr I think and the others are a bit over 100gr. Going off memoy here
You don't need the Z06 valves unless you really plan on 7k rpm speeds.
But, if you can find them cheap and install them, you might as well.
manley845 is offline   Reply With Quote
Old 12-01-2010, 05:34 PM   #5
Toxiclemonade
CF Senior Member
Perfect, thank you.
Old 12-01-2010, 05:40 PM   #6
manley845
CF Senior Member
manley845's Avatar
Perfect, thank you.
Welcome
Old 12-01-2010, 05:57 PM   #7
C5XTASY
CF Senior Member
C5XTASY's Avatar
I believe the 2002-2004 Z06 heads came with the sodium filled valves. The 2001 Z06 and all standard C5s did not.
Ed
C5XTASY is offline   Reply With Quote
Old 12-01-2010, 06:23 PM   #8
LoneStarFRC
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
LoneStarFRC's Avatar
Location: "If you like your border, you can keep your border, suckah. Period! If you like your immigration laws, you can keep your immigration laws, fool! Period!
Sodium-filled hollow-stem valves are about more than just weight reduction. In operation, the sodium liquifies, conducting heat away from the valve itself and into the cylinder head. The technology has been around for a very long time, mainly on truck engines in years past.
HTH
LoneStarFRC is offline   Reply With Quote
Old 12-01-2010, 06:56 PM   #9
zeevette
CF Senior Member
zeevette's Avatar
Quote:
HTH
I remember the 1970 Buick GS455 Stage1 had them, so they've been around a while.
__________________
'02 black/black. LGM headers/cats/X. iForge "Aero" 18/19 combo. Koni FSDs. Trickflow/TEA heads,and HS rockers, MGW shifter.A&A Vortech V3si trim, and A&A COMP blower cam.RPS Twin Carbon Street. Tick master. Diff by RKT56. ECS brace. Pfadt diff brace. Somebody stop me...
I should be careful what I ask for....
zeevette is offline   Reply With Quote
Reload this Page sodium filled valves???
Tags
2001, 2004, 241, 243, buy, corvette, did, difference, filled, heads, sodium, soudim, valves, year, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
