AFR Heads
Old 12-05-2010, 01:08 AM
bucketlist1957
bucketlist1957's Avatar
Default AFR Heads
Who is running the new 210 heads? If you are running AFR Heads what are you doing for valve covers or coil pack mounts?
Old 12-05-2010, 01:33 AM
TriplBlk
TriplBlk's Avatar
Thought Id learn something new real quick from ya. Why are they doing 210's so close to the 215's?
I always thought the 215's were for the Stock CID LS1, What would be the use of 210's?
Old 12-05-2010, 07:33 AM
Rob's 73
Rob's 73's Avatar
I am sure you could use the factory valve covers. You can on the 205s.
Old 12-05-2010, 08:49 AM
vettenuts
vettenuts's Avatar
I am running 205's with stock valve covers, although I did do some clearing work inside the valve covers for the rocker arms. I have several threads in the archives on my 205 setup preparation and installation.
I checked your profile and since you have a 97 you will need a later set of valve covers. I found my set with an 04 valley cover brand new on fleabay that were removed from a crate motor.
Old 12-05-2010, 04:16 PM
bucketlist1957
Default Just looking
I was just interested to see if anyone on the forum was running these heads. I was reading the AFR catalog. I am going to do a HC package in the future. I have had people recommend all 3 of these heads. I understood the 210's were new just interested to see what people thought of them. Every vette shop has their personal favorites. I like hearing from the actual users. I am not ruling out anything. Trick Flow, Patriot any of them.
Old 12-05-2010, 10:45 PM
bucketlist1957
Default AFR Heads
Is anyone running anything other than the 205 AFR heads?
Old 12-06-2010, 10:31 AM
Flatlander
Flatlander's Avatar
I thought the 210s were going to be replacements for the 205s?
Old 12-06-2010, 10:55 AM
kp1
kp1's Avatar
Looks like that's correct.
Old 12-06-2010, 10:17 PM
bucketlist1957
Default Heads
I have a 2010 Catalog and Tech Guide AFR just sent me. Doesn't mention anything about discontinuing the 205s. Doesn't sound to me like many people are using any of them. I am kind of surprised.
Old 12-07-2010, 11:53 AM
kp1
kp1's Avatar
They don't show the 205 on their website. The 210 has the same part # the 205 had.
http://www.airflowresearch.com/index.php?cPath=76
To AFR Heads
Quick Reply: AFR Heads
