How to avoid the wheel hop
Old 11-01-2010, 01:47 PM
Hvymtlc5
Hvymtlc5's Avatar
Default How to avoid the wheel hop
Is there any cheap way to avoid serious wheel hop? tire compound, air pressure, launch technique...
Took my 01 to the strip for the first time since performance mods were added.......wheel hop in 1st, 2nd....running Toyo 888R with 30 PSI no burnout
2nd run wheel hop during burnout , hop again in 1st......broke the differential
Car ran a 13.0 @ 125mph... not too bad with multiple gear hop.... but hard on the wallet.
Old 11-01-2010, 01:51 PM
CarsRFun
CarsRFun's Avatar
since ur rear diff is shot anyway id slap one of these on there while everything is a part
http://www.eastcoastsupercharging.co...rut_Brace.html
Old 11-01-2010, 01:58 PM
Dope
Resident moron
Support Corvetteforum!
Dope's Avatar
The DTE brace is nice to keep everything together. Getting a good tranny mount (VBP, pfadt) is very helpful. Good shocks will help too. Poly bushings will help. Basically you want to minimize deflection in your drivetrain/suspension to avoid wheelhop.
Dope
Old 11-01-2010, 02:03 PM
Chris Stewart
Chris Stewart's Avatar
Increase the traction or try to modulate the wheelspin. Too much spin too fast = hop.
Old 11-01-2010, 02:56 PM
Hvymtlc5
Hvymtlc5's Avatar
well already had that piece...
with car jacked up and in gear the driver wheel will not turn by hand. The passenger wheel "freewheels". With tranny in neutral, both wheels "freewheel" there is no poitive traction/limited slip taking place where they both rotate together - would this be a symptom of bad spider gears?
Old 11-01-2010, 03:44 PM
YeloFevr
YeloFevr's Avatar
Put a DTE brace on my car and I couldn't believe how it eliminated wheel hop. Kept everything nice and square under heavy throttle.
Old 11-01-2010, 04:01 PM
Z06pete
Z06pete's Avatar
Can A DTE brace be installed without dropping the transmission out of the car?
Pete
Old 11-01-2010, 08:53 PM
corvettebob1
corvettebob1's Avatar
Or a broken rt side O/P shaft.
Old 11-02-2010, 07:49 AM
Hvymtlc5
Hvymtlc5's Avatar
Is this the long shaft or the short? I had a long O/P ( hardened )put in when the new clutch went in...that should not have broke.
Old 11-02-2010, 09:54 AM
bumble-z
bumble-z's Avatar
This is all speculation, in regards to what broke.
At the very least, you need to pull the differential and go from there.
With as much HP as you are running, you will need excellent rubber in the rear to correctly launch. Your going to need slicks or at the bare minimum a really good drag radial tire. Worn/Street tires will be not be efficient.
Old 11-02-2010, 09:58 AM
bumble-z
bumble-z's Avatar
Pete
Dropping the rear cradle down a few inches, with every thing still intact, would give you enough room to install. It still wouldn't be a fun thing to do.
Old 11-02-2010, 11:03 AM
SaberD
SaberD's Avatar
it has to do with the harmonics of the rear of the car. sometimes something simple like changing shocks can completely eliminate it. you could also try a different spring or try using different brands of tires and different profiled tires. You could also switch to adjustable coilovers and experiment with different rates. Changing sway bars, sway bar bushings, and control arm bushings can also have an effect. Adding or removing weight from the rear of the car can change the harmonics also. as others have stated, you can also get a trans and diff brace.
Old 11-03-2010, 09:52 AM
099blancoss
Former Vendor
99blancoss's Avatar
St. Jude Donor '10-'11-'12
shocks
Old 11-03-2010, 09:18 PM
warren s
warren s's Avatar
Must be one fast car!!
All that wheel hop - getting off the gas and back on again and it still trapped at 125?
What are you doing with street tires?
Old 11-03-2010, 10:45 PM
76 VETTE
76 VETTE's Avatar
I just noticed wheel hop yesterday for the first time.I was atributing it to worn tires and the 45 degree weather here in n.y..
Old 11-03-2010, 11:59 PM
coolhand5599
coolhand5599's Avatar
Short answer. YES Long answer thier are way to many things to consider. I would need alot more info. The main thing is to let off as soon as you feel it. You will tear your car up bad if you try to drive through wheel hop. Alot has to do with the track
Old 11-04-2010, 01:23 AM
rustyguns
rustyguns's Avatar
cheapest way is to road race the Vette because it was designed to road race not drag race
Mustangs with solid rear-ends are good dragsters
To How to avoid the wheel hop
Old 11-04-2010, 01:54 AM
Chris Stewart
Stangs wheel hop too if you spin em too hard too fast.
Old 11-04-2010, 02:31 AM
BTHRB4U
BTHRB4U's Avatar
1. get an alignment
2. get some slicks with a decent sidewall hight
you want to eliminate the toe in effect that happens during hard acceleration, like stated above poly bushings, trans/diff mount, beefy rear sway bar and a set of shocks or coil overs.
Old 11-04-2010, 04:05 AM
rustyguns
rustyguns's Avatar
good! make the world a better place...go blow up a Stang
Quick Reply: How to avoid the wheel hop
