Disconnecting battery Question
when car is off is light by the volume control blinking?
if it is it is on, if not it is off.
read in your owners manual on how to set it.
either you did or a previous owner.
it comes from the factory off so you can set it.
lol unless you wanna arc weld somthing under your hood negative first
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Always NEGATIVE disconnect first. RECONNECT last. Been that way for E V E R!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Received 1,678 Likes
Another vote for disconnecting the negative first!
Received 8,955 Likes
Always do the negative first. This is especially important on metal cars where all of the metal is tied to the battery negative post. If you accidentally touch a metal part with the wrench while taking off the positive cable you will quickly start welding the wrench, will generate a large blue white spark that will temporarily blind you and hot pieces of the wrench may fly around and damage other things.
On the Vette that isn't quite as important because most things (other than the negative terminal and attached cable) don't conduct electricity so if you hit a body panel or other car part the chance of shorting out the battery is greatly reduced.
Bill
Bill
obviously the votes are in and yes i agree with all as well, just thought i would give you what i was taught as a teenage that kinda stuck with me like a nursery rhyme
red on first.....red off last
say it like ten times for the next few days and it'll be with ya forever
hope it helps
hope it helps
I always thought negative first as well. Then one day I had a problem with the car not starting and got the "pull Key wait 30 seconds" message. In the end it wouldn't start. I went through the manual is it said to pull the POSITVE only and wait one minute , then reinstall. Sure enough it worked and that was the end of it.
Apparently, the passcode wasn't send from the BDM to the PCM and pulling the positive only triggered a reset. Really strange.
Still, other than that, negative first.
