C5 headlight doesn't work
Old 09-30-2010, 12:34 AM
bkjackson55
2nd Gear
bkjackson55's Avatar
Default C5 headlight doesn't work
My driver's side headlight was hit and miss on opening and is now not opening at all--the headlight comes on, but doesn't flip up---WTF?
Old 09-30-2010, 12:50 AM
DarkSpeed
DarkSpeed's Avatar
either the motor is burned out,,,or a loose connection. I had a problem with the light not coming on,,,cleaned the connectors and worked fine
Check and clean the connections,,,if nothing, then replace motor
Old 09-30-2010, 12:53 AM
ICUALL
ICUALL's Avatar
Default Anbother Option
A special THANKS to Brent Franker http://bfranker.badz28.com for A great price and SUPER fast shipping on a Brass Replacement Headlight Gear ! BTW for those having issues or those with C-5's that are over 3 years old you might want to read about the "loose headlight motor issue BEFORE you strip a gear !! http://www.bfranker.badz28.com/headlightfix/index.htm
Old 09-30-2010, 02:08 AM
00Corvette
00Corvette's Avatar
search will show this is a very common issue...I think there are other threads on the front page at this very moment here in this section or the general.
the brass/metal gear kit is what you need more than likely
Old 09-30-2010, 01:12 PM
wayne_69_427
wayne_69_427's Avatar
Had the same problem about a month ago. Ordered the brass gear kit and installed it everything is working fine now. I found that the plastic gear had a rough or flat spot on the teeth of the gear.
To C5 headlight doesn't work
Quick Reply: C5 headlight doesn't work
