PO530 code - removed A/C - what voltage is necessary?
Old 09-16-2010, 10:40 PM
RX-Ben
RX-Ben's Avatar
Default PO530 code - removed A/C - what voltage is necessary?
I am getting a PO530 code b/c I removed the A/C and I think it is causing a CEL (that is the only code that shows up when I check PCM codes). I'd like to feed the wires the proper voltage to avoid the code - anyone know what it should be (someone please test!!)?
Thanks!
Old 09-16-2010, 10:48 PM
lucky131969
lucky131969's Avatar
Thanks!
A P0530 will not cause a check engine light. Are you using a scanner, or checking codes through the DIC?
Old 09-16-2010, 11:29 PM
RX-Ben
RX-Ben's Avatar
checking through the DIC.
Good to know.
I need to pull the latest round, but that was the only thing that showed up previously so I thought I'd check in advance.
To PO530 code - removed A/C - what voltage is necessary?
Quick Reply: PO530 code - removed A/C - what voltage is necessary?
