Is my car possessed??
Old 09-15-2010, 11:03 PM
bwgreen
bwgreen's Avatar
Default Is my car possessed??
While driving up the turnpike today, my door locks started locking and unlocking by themselves. Happened 20 - 30 times. At the same time, my Emergency Brake Light (which has been stuck on for a couple weeks) started flashing on and off. The clicking locks stopped and the 'stuck' brake light is now off. Ideas???
Old 09-15-2010, 11:10 PM
lucky131969
lucky131969's Avatar
The brake light will also come on if you have a low brake fluid level, or a problem with the brake fluid level sensor/wiring.
Old 09-16-2010, 05:59 PM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
You might want to look for water in or around the BCM just in case water is getting into it. Pull your codes.
Old 09-16-2010, 11:28 PM
Rohan
Support Corvetteforum!
Rohan's Avatar
An exorcism might not be a bad idea either... You know, just to be safe.
To Is my car possessed??
Quick Reply: Is my car possessed??
