Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-27-2002, 02:48 PM   #1
HoTRocks
Junior Member
Default seemingly low oil pressure on a 2002 C5
i have a new 2002 C5,which replaces my 99 C5. The 2002 has low oil pressure when at hot idlecompared to my 99. At warm/hot idle i am only showing 20-23 psi of oil pressure, is this normal, my 99 under the same conditions would read 30 psi, Has GM modified the oiling system since 1999, or do I have a low pressure condition, thanks for all replies.
HoTRocks is offline   Reply With Quote
Old 03-27-2002, 03:11 PM   #2
Corvette SSX
CF Senior Member
St. Jude Donor '08
Corvette SSX's Avatar
Default Re: seemingly low oil pressure on a 2002 C5 (HoTRocks)
Here is the fix. Change the oil and the pressure will rise. It will work. I've seen it on many cars, including my own. Do not take it to the dealer for this problem as they will have no clue.
Corvette SSX is offline   Reply With Quote
Old 03-27-2002, 04:02 PM   #3
MAGRED 02
CF Senior Member
MAGRED 02's Avatar
Send a message via AIM to MAGRED 02
That's the same problem when I had my 99 A4, but now that I have a 2002 M6 the pressure runs around 40 Psi @ running temp.
MAGRED 02 is offline   Reply With Quote
Old 03-27-2002, 04:08 PM   #4
RyanC6
CF Senior Member
RyanC6's Avatar
Send a message via AIM to RyanC6
Default Re: seemingly low oil pressure on a 2002 C5 (MAGRED 02)
Mine chimes in at 40
RyanC6 is offline   Reply With Quote
Old 03-27-2002, 04:08 PM   #5
DsC5
CF Senior Member
DsC5's Avatar
Default Re: seemingly low oil pressure on a 2002 C5 (CorvetteSS)
Click the image to open in full size.
I haven't been able to figure out why, but my oil pressure went up a lot after I did my first change. That should take care of your problem. :seeya
DsC5 is offline   Reply With Quote
Old 03-27-2002, 04:57 PM   #6
1SGRET
CF Senior Member
St. Jude Donor '12-'13
1SGRET's Avatar
Default Re: seemingly low oil pressure on a 2002 C5 (DsC5)
40 here.
1SGRET is offline   Reply With Quote
Old 03-27-2002, 05:40 PM   #7
RajunCajun2001
CF Senior Member
That seems pretty low...try changing the oil, but if that doesn't work better take it to the dealer quick!
RajunCajun2001 is offline   Reply With Quote
Old 03-27-2002, 09:31 PM   #8
bojangles
CF Senior Member
Support Corvetteforum!
bojangles's Avatar
Default Re: seemingly low oil pressure on a 2002 C5 (RajunCajun2001)
Ditto on the oil change.. I had to change the oil 2x but it's runnning
around 40# with 11,000 miles..
bojangles is online now   Reply With Quote
Old 03-27-2002, 09:55 PM   #9
JWD01
CF Senior Member
JWD01's Avatar
Default Re: seemingly low oil pressure on a 2002 C5 (cares)
Here's what mine runs: 36 PSI @ idle and 48 PSI @ 2000 RPM, water temp.-196, oil temp.-199. This is with 400 miles and the original oil. I have been keeping track because I want to see the difference when I change the oil to 10W-30 mobil1 and the UPF-44 filter. I will change the oil at 500 miles. Unfortunately the weather sucks so that might be a while longer. :cheers:
JWD01 is offline   Reply With Quote
Old 03-28-2002, 01:25 AM   #10
Vespa-Vette
CF Senior Member
Vespa-Vette's Avatar
Default Re: seemingly low oil pressure on a 2002 C5 (JWD01)
I read your post so I double checked mine on the way home.
2000 Coupe w/17K miles & 4 prior oil changes.
40psi @ speed
25psi @ idle
Vespa-Vette is offline   Reply With Quote
Old 03-28-2002, 12:51 PM   #11
Speed-Racer
CF Senior Member
Speed-Racer's Avatar
Default Re: seemingly low oil pressure on a 2002 C5 (Vespa-Vette)
At cruise, 40psi on my A4
Speed-Racer is offline   Reply With Quote
Old 03-28-2002, 01:18 PM   #12
Patches
CF Senior Member
Patches's Avatar
Default Re: seemingly low oil pressure on a 2002 C5 (Speed-Racer)
Mine's been rock solid at idle since Day 1 - warm and idle=40psi.
One oil change so far at 750 mi with M1 and UPF-44.
Patches is offline   Reply With Quote
Old 03-28-2002, 08:04 PM   #13
BlackZee06
CF Senior Member
BlackZee06's Avatar
Default Re: seemingly low oil pressure on a 2002 C5 (Patches)
FWIW, I looked in the 1999 C5 shop manual and found the following info:
Oil Pressure (Minimum --- Hot)
6 psi @ 1,000 RPM
18 psi @ 2,000 RPM
24 psi @ 4,000 RPM
I hope this helps
BlackZee06 is offline   Reply With Quote
Old 03-28-2002, 09:10 PM   #14
MySea6
CF Senior Member
MySea6's Avatar
Do what SS says and change the oil and filter. It will work. :cheers:
MySea6 is offline   Reply With Quote
Old 03-28-2002, 09:20 PM   #15
Corvette ED
CF Senior Member
Corvette ED's Avatar
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default Re: seemingly low oil pressure on a 2002 C5 (MySea5)
Also put 10/30 Mobil 1 in it instead of 5/30.
Corvette ED is offline   Reply With Quote
Old 03-28-2002, 09:24 PM   #16
GasmanZR1
CF Senior Member
My oil pressure was low in my 2001 coupe at first as well. Like the others have said, it went up after my first oil change, using the UPF44 filter. I don't know if it was the filter or what, because this is the only filter I have used. There is a wide range of normal operating pressures, so I wouldn't worry too much about it.
Michael
GasmanZR1 is offline   Reply With Quote
Reload this Page seemingly low oil pressure on a 2002 C5
Tags
10, 2000, 2001, 30, 36, 99, c0rvette, c5, corvette, low, oil, pressure, psi, rpm, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
