Climate Control Display
My 02 Vert's climate control display light has gone out, every once in awhile it comes on and fades out. How do I replace it.
If it is the Numbers then here is your fix.
If it is the Numbers on the display that fade in and out and come brighter when you tap on it, here is the absolute fix, but it also discusses the bulbs and replacement for backlighting.
http://forums.corvetteforum.com/c5-t...splay-fix.html
Look nowhere else.
I hope this helps
Look nowhere else.
I hope this helps
