You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Has anybody tried one of these? Do they work? Price reduced from $400 to $70! http://www.gforcechips.com/chevroletcorvette.aspx
I'm thinking if they really worked then they could get $400 for them all the time and wouldn't need to put them on sale...
DocOhm
DocOhm
Your the THIRD person this week that has asked the same question.
C5 and C6 corvettes DO NOT use chips. The PCM has a FLASH Memory. The PCM tuning is done with a OBDII serial interface cable and the new data is written over the old data.
There are several methods that you can use to reprogram your PCM..
If something sounds too good to be true then... well you know the rest.
It says it plugs inline with the air intake temp sensor. so i would think it fools the ecu into thinking its running cooler air and it adjusts for it.
It is just a 3 cent resistor to fool your Intake Air Temperature to think it is cooler and and will push more fuel with the mixture and slightly increase timing.
