Should TPMS Sensors Be Replaced? How Often?
Received 1,817 Likes
You can buy the tire pump from what you save by buying one non-runflat tire, versus a runflat. Buy two tires, and you've saved enough for AAA premium road service, which gets you flatbedded for 100 miles. Might not be enough, but how far can you go on a runflat with no air???
If the car is the airhead "trophy wife's" daily driver, runflats are probably needed. If that's the case, you've bent over and grabbed your ankles with your pants down plenty of times already, so just go with the runflats.
If you value performance, I don't know of any tire tests which put runflats at the top of the pack.
Thx
Dave
Dave, you don't even have to have the sensors mounted in the wheels to test them.
I programmed my new sensors, with them sitting on my lap, from inside the car.
