Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-27-2010, 01:17 AM   #1
0TheRadioFlyer97
CF Senior Member
St. Jude Donor '08
TheRadioFlyer97's Avatar
Default Milling heads for more compression?
A few guys on LS1 tech have suggested I mill the 243 heads i'm getting about .020" from the deck which should bring compression to 11:1.
a) has anyone tried this?
b) about how much $$$ does this job cost?
c) how does compression affect throttle response? Is is similar to that of a stroked engine?
TheRadioFlyer97 is offline   Reply With Quote
Old 05-27-2010, 06:22 AM   #2
vettenuts
CF Senior Member
vettenuts's Avatar
Send a message via AIM to vettenuts
Compression is definitely a plus. What cam are you running? You need to also make sure the shop that does the milling can hit the flatness and surface roughness required for the gaskets you will be running. My compression is 11.3 but I am also running a thinner gasket to help with detonation. There are calculators you can use to figure it out.
vettenuts is offline   Reply With Quote
Old 05-27-2010, 06:58 AM   #3
ipuig
CF Senior Member
St. Jude Donor '09
ipuig's Avatar
I paid $110 plus tax to have my heads milled. Of course they were already off the engine and I delivered them to the shop.
I replaced my cam during the same tear down, so I cannot say how much of the added power was strictly due to the increased compression ratio.
ipuig is offline   Reply With Quote
Old 05-27-2010, 07:45 AM   #4
legman
CF Senior Member
legman's Avatar
Quote:
I plan on milling my 243's during my next mod project too. Am I correct in thinking all else being equal, .025 from heads would or should equate to 7.375 pushrods??
Also, Vettenuts, can you explain how running a thinner gasket would help with detonation ??
Sorry to the OP if this looks like a hi-jack.
legman is offline   Reply With Quote
Old 05-27-2010, 08:49 AM   #5
Blow Torch
CF Senior Member
Blow Torch's Avatar
As VN mentioned, there is a calculator that will help you figure how much material removed translates into how much compression boost.
The biggest improvement I notice when I bump compression is the throttle response. BIG difference!
Blow Torch is offline   Reply With Quote
Old 05-27-2010, 10:06 AM   #6
0TheRadioFlyer97
CF Senior Member
St. Jude Donor '08
The Good news is that i'm stillin project planning/parts purchasing. I'm picking up the 243 heads tomorrow.
so far this is the cam i'm shooting for: 221/226 .565/.560 114
http://sdparts.com/details/scoggin-d...-center/sd0067
Old 05-27-2010, 04:42 PM   #7
zeevette
CF Senior Member
zeevette's Avatar
I recommend calling TEA, and explain your setup/goals, and see how much they'd charge to do your 243s. I think you'd be happier with the results of a integrated design, than just milling the heads to bump CR. About the thinner gaskets to help reduce detonation..... thinner gaskets reduce "quench"; the gap remaining at the top of the cylinder/head interface can produce hot spots, which can induce detonation. It's not a problem unless your pushing the limits of timing/gas quality/CR. I went to 10.95 CR, with 8.55 DCR, and with the factory MLS gaskets, which I believe are about .055 compressed, got absolutely no knock retard with 92 octane gas. I don't know my timing numbers, though.
__________________
'02 black/black. LGM headers/cats/X. iForge "Aero" 18/19 combo. Koni FSDs. Trickflow/TEA heads,and HS rockers, MGW shifter.A&A Vortech V3si trim, and A&A COMP blower cam.RPS Twin Carbon Street. Tick master. Diff by RKT56. ECS brace. Pfadt diff brace. Somebody stop me...
I should be careful what I ask for....
zeevette is offline   Reply With Quote
Old 05-27-2010, 05:20 PM   #8
jpandes
CF Senior Member
jpandes's Avatar
I'm interested in this too. What gains can you expect from just milling the heads and a retune?
jpandes is offline   Reply With Quote
Old 05-27-2010, 05:34 PM   #9
Paul 75 L82
CF Senior Member
Paul 75 L82's Avatar
Send a message via AIM to Paul 75 L82
The experts would tell you to check valve to piston clearance.
Paul 75 L82 is offline   Reply With Quote
Old 05-27-2010, 05:51 PM   #10
ctusser
CF Senior Member
ctusser's Avatar
Quote:
He'll be fine with the 221/226 cam he's running.
ctusser is offline   Reply With Quote
Old 05-27-2010, 06:16 PM   #11
0TheRadioFlyer97
CF Senior Member
St. Jude Donor '08
Quote:
Well i plan to run 1.8 rockers with this cam:
I'm repalcing both lifters and pushrods as well so I can get custom lengths if requried.
Old 05-27-2010, 08:02 PM   #12
ctusser
CF Senior Member
ctusser's Avatar
Its the duration and lsa more than the lift. By the time full lift is achieved the piston is inches down.
Old 05-27-2010, 10:59 PM   #13
0TheRadioFlyer97
CF Senior Member
St. Jude Donor '08
Are you saying my setup should clear? I'm not familier with the total valve lift formula.
Old 05-27-2010, 11:19 PM   #14
ctusser
CF Senior Member
ctusser's Avatar
It's not the total lift that gives you problems with piston to valve contact, because when the valve is all the way open the piston is near the bottom of its stroke and at the bottom of the cylinder. The large duration cams which keep the valves open longer when the piston is comming up is what causes the PTV issues. That is a small cam and you wont have problems with contact even if milling .020 to bump compression.
Old 05-27-2010, 11:23 PM   #15
0TheRadioFlyer97
CF Senior Member
St. Jude Donor '08
schweet
Old 05-28-2010, 01:34 PM   #16
AU N EGL
CF Senior Member
AU N EGL's Avatar
with 1.8 rockers that will put the lift over .600, however that is dead bottom center.
AU N EGL is offline   Reply With Quote
Old 05-28-2010, 02:14 PM   #17
Blow Torch
CF Senior Member
Blow Torch's Avatar
Make sure you talk to the cam manufacturer to make sure you can run 1.8s with their cam. Some will tell you not to
Old 05-28-2010, 03:53 PM   #18
0TheRadioFlyer97
CF Senior Member
St. Jude Donor '08
On suggestion from my mechanic, i will not be milling my heads. My block has 130K miles on it and I'd prefer not to overstress it much. I think 10.5 compression will be just fine.
Reload this Page Milling heads for more compression?
Tags
020, 20, 221226, 243, 560, 565, bump, cam, compression, cylinder, gain, heads, ls1, milled, milling, ratio
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
