TRANS PROBLEM, HELP NEEDED? Thanks
Hello, I bought a 1998 Corvette Automatic with 50k miles, 2 days of driving my trans is acting up? When I take off slowly it wont switch into second gear until around 4200 RPM, for me thats very high considering I am driving slow! Also, if I floor the car and give it gas all the way the RPMS jump up but it will not switch a gear it will just redline the car and wont go past 60 MPH, but if I take off slow it will go past a 100 MPH normaly but u can tell its strugling to get into gears? And I also noticed some times u have to hit the brake while driving for it to fall into the next gear it seems? Basicly the car is drivable, but it has hard time switching gears and it CANT BE FLOORED or it will redline the engine with out geting into the next gear! Also the trans fluid reads between 170-220 degrees on the dash when I look it up? When I bought the car every thing was normal, however the next day I drove it all day doing 160 MPH a few times, and kept flooring it a few times! I think thats what messed it up, but its a Vette its ment to be floored ones in a while! When I bought the car I checked all the fluids besides the trans fluid, since the trans fluid dipstick is under the car I was going to get the trans fluid flushed or checked on my next day off since I didnt know if it had any trans oil in there or if it needed to be flushed since the car was sitting in the garage for 4 years stored, but before I had the chance the trans started acting up 2 days after I bought it, I know it's beacause I kept flooring it for 2 days, but could this problem have accoured if there was not enough TRANS oil in there? What do I do, or what have I done? Any ideas will be appriciated, thank you!
7th Gear
Vettaholic
Allright , first of all, there is NO trans dipstick on C5 corvettes.
If the car was in storage for 4 years, fluid needs to be changed.
Do that first.
One last question, has the car been tuned ? Some pple have the shift points adjusted to shift at higher RPM.
Patrick
Do that first.
Patrick
Vettaholic
I said that because from my understanding of the OP:
1) trans fluid was not checked
2) no idea how it was driven prior to purchase
3) OP did not state when the fluid was changed last
Hence I assumed the worst....
But I guess you're right, a fluid check could show he's OK in that department, and the problem lies elsewhere (clutch pack ?)
Patrick
Patrick
The car has never been tuned, I just dont know weather to first change the trans oil n filter and see if that fixed the problem, but I dont think it will... And I dont know where to take the car, the Dealer or? Now days no one has the time or money for people to be guessing at shops, I need some one who knows what their doing and talking about in the shop you know. I heard all places want 400 plus just to take the trans down and see whats wrong?
It would help if you filled out your CF profile. People would then know where you lived and locals could jump in with references in your area.
This is a great community with a wealth of knowledgeable people who are willing to help, but, they need to know your location.
Good luck.
Good luck.
