OK, what did i miss
OK, what did i miss
I lowered my car on the stock bolts ,turned the fronts all the way then backed off a hair,had i nice gap that i was happy with,cut the shims in the rear so i had a equal gap front to rear,drove it for a 100 or so miles and it settled a bit more,PERFECT.i take it for an alignment and the front gap has been moved up quite a bit,what am i missing,was i not supposed to realign? whats up
Maybe they had the car in the air and now it has to settle in again. Maybe they saw the bolts and thought it was a problem and put them back to stock position.
St. Jude Donor '10
I gained a finger on my C4 when I lowered it- ran it for a while without aligning, then decided to. Was not real happy as I was used to the height I had and it easily gained 3/4" rise.
I've got my C5 set where I want it, I will drop it 1/2" more if I decide to align it.
All you can do at this point is cut the front bushing off the lowering bolt, lower it more than you want it, then re-align, which will bring it up prob 1/2". Running the car with it out of camber will eventually wear the inside of the tire sooner than the rest of the tire, but it's great for corners.
First I've heard of someone cutting the rear bushings, although that's what I did the day before I read this. The rear aftermarket lowering bolts are too long and even when fully tightened, was still too low (no spring left), so I maxed out the stock bolts along with cutting 1 section out of both top and bottom bushings.
