Service ABS, Service Traction Control, Service Active Handling
Old 03-28-2011, 09:30 PM
  #501
billyward
billyward's Avatar
Default abs
please send to me too!
Old 03-28-2011, 09:54 PM
  #502
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
It is posted in the DIY sticky.
Old 03-28-2011, 10:09 PM
  #503
billyward
billyward's Avatar
what is diy sticky!
Old 03-28-2011, 10:55 PM
  #504
Mr.Bill
Mr.Bill's Avatar
what is diy sticky!
Do It Yourself....
...Members are reminded that all this information with Photos is available for download at the start of the C5 Tech section in POST #66
Sticky: The Improved***** Ultimate DIY Thread ... ******* (Multi-page thread )
Old 03-28-2011, 10:57 PM
  #505
69SSC5
69SSC5's Avatar
what is diy sticky!
diy = do it yourself... and a sticky is a perminant thread/posting listed at the top of the forum
  #506
ndirishr1
ndirishr1's Avatar
FYI just another THANKS! and to let you know that you guys are great. I just went through this DIY exercise and I figured your info helped me save $1430 over a trip to my friendly GM dealer to fix this problem. Thanks again!
Old 03-29-2011, 05:34 AM
  #507
trussme
trussme's Avatar
Default Your are Welcome!
Glad my 2 tutorials helped save you $$$... I've sent them out in over 400 member emails since 2007..."Pewter" figured I needed them in a STICKY so he put them in the Ultimate C5 DIY Thread Sticky .....Post #66....
Bill (trussme) Trussell
Old 03-29-2011, 09:24 AM
  #508
nvusgt
nvusgt's Avatar
jesus christ! If I were either Mr.Bill or Trussme, I'd shoot myself. How many times do people have to be reminded of this:
Do people just jump in here, not read a single word and ask for the damn info?!? This thread wouldn't be half as long if people would read. I'm a little curious how they intend to fix their issues if they can't do a little digging for themselves in an online forum.
Sorry, just my .02 cents.
edit:
fyi, I have done plenty of digging. So much so I fixed my OWN EBCM, with a "how-to remove it," "how-to disassemble once removed" and finally fixing the retarded little relay whose solder points come undone. As well as hitting the major ground points along the car and oh one other thing my own CLB relay from ANOTHER diy on this very forum. Saved...250 for absfixer right? Also 50 or 60 for a simple clb relay from one of the vendors. Cleared all codes and no issues with either TCS or my CLB.
All the info is available, you simply need to apply yourself and you'd be amazed at how much you learn and the amount of money you save. But it all starts with READING!!!
Old 05-10-2011, 10:38 AM
  #509
radvetter
8th Gear
radvetter's Avatar
Default Active handing problems
Bill, could you please send it to me as well. I too am seeing the TC and AH lights on my 03. Would love to fix the problem without taking it to a shop. radvetter@yahoo.com
Old 05-10-2011, 10:42 AM
  #510
radvetter
8th Gear
radvetter's Avatar
Default Active Handling problems
Wow, I guess I can get this off the website. Never Mind.
Yea, I guess I didn't read far enough.
Thanks guys!!!
Old 05-20-2011, 03:05 PM
  #511
loungnlizard
6th Gear
loungnlizard's Avatar
Bill, appreciate you sending it to me as well at:
loungnlizard@yahoo.com
Thank you!
Old 05-20-2011, 07:06 PM
  #512
NEED2SPEEDLS1
NEED2SPEEDLS1's Avatar
Do you need to clean all the connectors out? Or is there an easier way to solve that light problem. I cleaned out one and it wasn't even that bad. Plz send an email to me if you can pfeifz28@yahoo.com
Old 04-30-2012, 03:44 PM
  #513
Jackman
Jackman's Avatar
It has been a long time now and I am still having problems with the ABS, Tracktion control indicators. I have checked most connectors and grounds and did not resolve problem yet. These are the current history codes I get. C 1214H; B 2282H, B 2284H, B 2264H, U 1064H;
B 2283H, B 2285H, B 2265H, U 1064H;.
What am I missing? What should I check? Thank you.
Old 04-30-2012, 04:40 PM
  #514
R CRYSIS
R CRYSIS's Avatar
Default 1997-2000 ebcm
I think what a lot of people also miss understand is the difference between the early 97 to 2000 EBCM which are non repairable and unavailable according to most even though there are some places that say they can fix some of the problems they have. Also there are two types from 98 to 2000 because active handling JL4 was an option during those years so you had an M code non active handling and a V code which was active handling if you have a 01 to 04 it's no big deal they are still available pretty cheap easy to remove and they can usually be repaired for a hundred bucks or so. I have fixed a few of the later ones for friends but I still can't fix my own car because it's a 2000 with active handling and the EBCM is hard to find. I have been looking for one for a while. I have checked everything on my car and read the posts and I feel confident that that is the problem.Then if I do find one someday(WISHFUL THINKING) in a wrecking yard how do I know if it's any good? Now we have the steering position sensor that is also no longer available for our early C5"s which can cause serious issues it is extremely frustrating. I know there is nothing we can do but I think it is ridicules that we can't get parts for a twelve year old car with 46K miles!!!!!!!! I just restored my 65 GTO I could buy everything I needed!!! Please God let someone start making these parts again! GM definitely left us high and dry
Old 04-30-2012, 06:30 PM
  #515
Jackman
Jackman's Avatar
Mine is a 2003 so I guess it's still cheap if I need one.
Old 06-30-2012, 12:46 AM
  #516
corvettez06ed
corvettez06ed's Avatar
Originally Posted by trussme
all preceding requests for tutorial just sent..
Hi Bill, is the tutorial just for 2001 and newer C5s?
Old 06-30-2012, 10:56 AM
  #517
jpranchranger
jpranchranger's Avatar
itz on the way
would this tutorial be of any help on a 2000 since they can not be repaired?
To Service ABS, Service Traction Control, Service Active Handling
Old 07-01-2012, 10:12 PM
  #518
hcb
hcb's Avatar
Mr Bill I seem to have the same problem. Can you also send me a copy?
aculcu@hotmail.com
Thanks, HCB
Old 07-06-2012, 10:53 AM
  #519
david riniti
8th Gear
david riniti's Avatar
Bill, I am new to the forum and would like the tuturial on the "service ABS, trac control, and active handling" problem. Could you please e-mail the info and pictures. Thank you. My e-mail address is dave917@verizon.net. Thanks again.
Old 08-27-2012, 01:26 AM
  #520
Blwthndr
2nd Gear
Blwthndr's Avatar
Hi Bill, I might as well get on the bandwagon, can you please send it to me as well? My baby is a 2004.
normmarcil@persona.ca
Thanks Norm
Quick Reply: Service ABS, Service Traction Control, Service Active Handling
