Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-07-2010, 05:53 PM   #21
Sully1882
CF Senior Member
Support Corvetteforum!
Sully1882's Avatar
Send a message via AIM to Sully1882 Send a message via MSN to Sully1882 Send a message via Yahoo to Sully1882
Default no change, problem remains
found the liquid electrical tape, applied it to the door connectors, especially around the clear serial wire that had pulled back and was exposed, and let them dry then put all back together. No change at all. Still showing in the DIC " service vehicle soon "
any other things I could check ???
Sully1882 is online now   Reply With Quote
Old 05-07-2010, 08:11 PM   #22
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill Curlee's Avatar
Next to the BCM,,,to the LEFT of it, there are TWO thin grey connectors. Those are the serial data STAR connectors. Find the connector that has FOUR wires. Pull the TOP of that connector and see if your issue goes away. That connector removes the serial data circuits from the LDCM, RDCM and the seat control module.
BC
Bill Curlee is offline   Reply With Quote
Old 05-10-2010, 03:27 PM   #23
Sully1882
CF Senior Member
Sully1882's Avatar
thank you Bill, will try it tonight!
Sully
Old 05-11-2010, 09:49 AM   #24
Sully1882
CF Senior Member
Sully1882's Avatar
with the weather here last night I was unable to work on the car last night. But... new symptom has arose. ABS is activating and going nuts. When I depress the brakes it feels like for sure the back brakes maybe more so the passenger side is clamping down! It even does it some when driving where it causes the tire to skid!!!!! When I had the brake pedal depressed it felt like the ABS was activating and causing a vibration through the pedal. Talk about scary! I limped her home last night and parked her. I am driving the old chevy truck today. Man I wish I had my Stingray finished... I would just drive it until I get this thing with the C5 figured out!!! Any ideas? Need to pull the codes again. I don't think I should try to drive it until this is all worked out.
Sully
Old 05-11-2010, 04:48 PM   #25
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have one or more of the following things going on:
- Alignment Issue. Is your steering wheel off center left or right when your going straight?
- Steering Wheel Position Sensor issue: The SWPS is going bad or giving out false outputs due to misalignment
- The EBTCM is going bad Dont even bother sending it out for repair.
Read and post your DTCs
BC
Old 05-16-2010, 07:37 PM   #26
Sully1882
CF Senior Member
Sully1882's Avatar
Default codes
ok guys here are my codes...
10-PCM P 1571 H C
28-TCS NO COMM
58-SDM U1040 H C
A6- SCM B2860 H
BO-RFA U1096 H
U1016 H
Bill, not to sound too ignorant but the BCM ( body control module) isn't that in the passenger side floor?
Thanks again for all the help so far and hopefully I can get this fixed. Till then I am not driving it b/c of the brakes kinda locking up on me and all.
Sully
Old 05-16-2010, 11:06 PM   #27
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BCM (Big Silver Box) in passengers foot well:
Click the image to open in full size.
You can see the STAR connectors to the left.
Old 05-17-2010, 09:34 AM   #28
Sully1882
CF Senior Member
Sully1882's Avatar
Default STAR connector
figured that's what those were when I went digging into that area. What does STAR stand for? The top one was the one with four wires and the bottom had many more than that. It was held by a simple metal clip onto a metal flange. I didn't do anything with it. Will tug on it tonight when I get home from work and get the kids down to bed. Thanks again for the pics!
Sully
Old 06-14-2010, 05:32 PM   #29
d1ngokellz
CF Member
d1ngokellz's Avatar
Quote:
Sully
just curious if your problem was cured??
d1ngokellz is offline   Reply With Quote
Reload this Page 2000 coupe DTC codes
Tags
2000, accordian, c5, check, code, codes, corvette, dtc, p1571, p1571hc, sdm, u1040
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
