Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-29-2010, 06:37 PM   #1
SEE3ER
CF Senior Member
Default Oil drain plug leak....?
Been trying to figure this ever-so-slow oil leak. Tiny drops surround the drain plug and spots the floor. Takes a few days to show up on the plug and floor after wiping clean. Changed the drain plug to a new one last fall, but same results.
Since this car is so low to start with, I wonder if previous owner may have slightly hit the front of the pan or plug just enough to mushroom the pan around the plug, and maybe the plug doesn't tighten up flush?
Anyone had this issue? Leak is definitely from plug area.
SEE3ER is offline   Reply With Quote
Old 03-29-2010, 11:23 PM   #2
ipuig
CF Senior Member
St. Jude Donor '09
ipuig's Avatar
You can start by replacing the o-ring gasket if you have not done so already.
ipuig is offline   Reply With Quote
Old 03-29-2010, 11:36 PM   #3
memphis_vette
CF Senior Member
memphis_vette's Avatar
yup my gasket broke on mine and it started leaking so i went with a magnetic bolt
memphis_vette is offline   Reply With Quote
Old 03-30-2010, 05:41 AM   #4
vettenuts
CF Senior Member
vettenuts's Avatar
Send a message via AIM to vettenuts
Did the new plug have a new seal on it? Take a close look for any cracks as well.
vettenuts is online now   Reply With Quote
Old 03-30-2010, 06:14 AM   #5
SEE3ER
CF Senior Member
yup...first thing I tried was a new seal, then a new plug...no luck.
Old 03-30-2010, 08:49 AM   #6
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14
Quicksilver Vert 01's Avatar
It sounds like the sealing surface, on the pan drain tapping itself, is not smooth and flat.
Try a soft copper sealing washer on the drain plug in place of the rubber seal.
Quicksilver Vert 01 is offline   Reply With Quote
Old 03-30-2010, 04:24 PM   #7
TEXHAWK0
CF Senior Member
TEXHAWK0's Avatar
When you had the plug out, did you inspect the oil pan surface to see if it looked smooth?
If the rubber gasket will not seal, I doubt that a metal gasket will seal.
TEXHAWK0 is offline   Reply With Quote
Old 03-30-2010, 04:28 PM   #8
SEE3ER
CF Senior Member
Last fall during the oil change and plug change I believe I only concentrated on the plug, as I dont recall seeing anything unusual with the pan. Will be changing oil soon, so inspection of the pan will be next. I'm thinking its "sort of mushroomed or slightly crunched" just enough to not seal correctly, otherwise I have no clue what it could be.
Old 03-30-2010, 09:39 PM   #9
C5FORFUN2
CF Senior Member
C5FORFUN2's Avatar
Quote:
I also changed to a magnetic plug and later noticed some slight leakage. I loosened the plug and applied some thread sealer to seal it up. (Didn't want to drain all the oil again.) No leaks now, but will need to check it out next oil change.
C5FORFUN2 is offline   Reply With Quote
Old 03-30-2010, 09:43 PM   #10
SEE3ER
CF Senior Member
Quote:
yup...I actually included teflon tape on the threads when new plug was installed....drip...drip...drip
Old 03-31-2010, 09:05 AM   #11
Quicksilver Vert 01
The plug has straight threads, not tapered threads like pipe fittings have. Teflon tape works best on tapered threads.
A thin coating of black silicone RTV over the rubber seal, before you install the plug each time, should stop the drip too.
Old 03-31-2010, 09:08 AM   #12
SEE3ER
CF Senior Member
but there must be something wrong if that is necessary?
Old 03-31-2010, 10:39 AM   #13
Quicksilver Vert 01
There has to be a casting flaw or an irregular surface in the lower oil pan section, at the drain plug hole tapping. You'll have to drain your oil to do a close inspection of the area.
Look for any nicks or burrs in that area, and remove them with a Dremel tool.
Old 10-25-2010, 04:05 PM   #14
SEE3ER
CF Senior Member
Well...the leak is back.......after draining oil, and inspecting pan a few months ago, I delicately filed the surface around the hole to ensure the surface was flat...installed new drain plug with seal. About a week ago started smelling the oil again ever so lightly sprayed over the bottom of the oil pan. Yet this time, no drops on floor. Smell is worse the more I drive especially at highway speeds.....is it time to change oil pan????
Old 10-26-2010, 11:03 PM   #15
C5FORFUN2
CF Senior Member
C5FORFUN2's Avatar
When I changed my oil I cleaned off the teflon tape and put on a thicker O ring. That solved it for me. You could also try "Gasket Eliminator" on the threads or maybe the oil is coming from somewhere else and running down to the plug? You probably already checked that tho.
Old 10-27-2010, 06:24 AM   #16
SEE3ER
CF Senior Member
yea, I've tried it all...inspected quite a few times, thread sealers, new gaskets etc., the only thing wet with oil is only around then plug.....out of options I guess...
Old 10-27-2010, 08:21 AM   #17
runner140*
CF Senior Member
Support Corvetteforum!
runner140*'s Avatar
Get a new magnetic drain plug and use a new o-ring nylon gasket. This worked for me several years ago. Make sure the leak is from the drain plug and not the pan or elsewhere.
runner140* is offline   Reply With Quote
Old 10-27-2010, 08:56 AM   #18
basicstrategy777
CF Senior Member
St. Jude Donor '11-'12-'13-'14
basicstrategy777's Avatar
An idea...........Use a tap to restore thread or create new thread or buy a specially made oversize drain plug from an auto parts dealer. The one you want is designed to rethread damaged threads in the oil pan, allowing the new plug to seat properly and seal the leak. Start the plug into the drain hole by hand, and then use a wrench to seat the plug. Stop turning as soon as the plug is secure.
Different seals/washers require different torque requirements, depending on the material they are made of; do not overtighten...do not undertighten.
I have heard chrome plugs work best.
777
777
basicstrategy777 is online now   Reply With Quote
Old 10-27-2010, 09:02 AM   #19
SEE3ER
CF Senior Member
All these ideas are good ones, but have been tried.....I am almost certain oil pan must have been "mushed" at one time by previous owner thereby causing the drain hole not to be round (cannot see this by eye, BUT- there is a "flat spot" at the very bottom of the hole in the pan..)not sure if this was cast this way or been hit......
the drip is so slow it takes weeks to appear...maybe trade this in for a C6....
Old 10-27-2010, 02:58 PM   #20
bumble-z
CF Senior Member
There you go. Problem fixed!!
bumble-z is offline   Reply With Quote
Reload this Page Oil drain plug leak....?
Tags
c4, c5, corvette, drain, draining, leak, leaking, oil, plug, plugs, proof, seal, sealant, sealer, teflon, thread
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
