PIN Locations
Old 03-25-2010, 03:07 PM
jimish
jimish's Avatar
Default PIN Locations
I need to locate pins 31 and 71 on the blue plug to the ECM. The computer has A,B,C and D, with arrows to each plug, but no numerical markings.
Old 03-25-2010, 03:23 PM
lucky131969
lucky131969's Avatar
I'm assuming for an 02?......not used.
Old 03-25-2010, 03:56 PM
jimish
jimish's Avatar
Exactly what I needed. Thank you so much. I understand by grounding pin 31 the trans goes into manual mode, and 71 will put it into the second programming mode (4 wheel drive)
Old 03-25-2010, 04:12 PM
dougbfresh
dougbfresh's Avatar
How can they do anything if they are not used?
Old 03-25-2010, 05:46 PM
lucky131969
Well that's interesting. On what GM model is that used?
Old 03-25-2010, 07:36 PM
jimish
jimish's Avatar
The EFI Live program calls the second program,4 wheel drive the performance program and says to momentarily connect to ground to use whatever you have programmed in. Likewise it says to use a second switch and momentarily connect to ground to go into manual mode.
Old 03-25-2010, 07:37 PM
jimish
jimish's Avatar
By the way, its an 02 drivetrain mounted mid engine in a 66 Corvair.
To PIN Locations
Quick Reply: PIN Locations
