Help
Help
Hello all.
Yesterday while driving on the freeway (65mph) it felt like the car was holding back. more like a pulse or if i were tapping on the brakes. it got worse as i decelerated. i thought it was going to stall on me cause the rev will drop to about 400 the jump to 700. i managed to find a safe place to pull over. checked all connections under the hood and everything checked out ok. i start the car, take off and everything is fine now! WTF? i didnt get any messages on the DIC but here are the codes i pulled up
28-TCS - Traction Control System
C1225 RF Excessive Wheel Speed Variation
C1232 LF Wheel Speed Circuit Open or Shorted
C1291 Open Brake Lamp Sw Contacts During Deccel
C1292 Set Curnt/Prev Ign Cylce
40-BCM -Body Control Module
B2578 RF Turn Signal Monitor Circuit (Short to Voltage)
B2583 LF Turn Signal Monitor Circuit (Short to Voltage)
B0-RFA - Remote Function Actuation
U1096 Loss of Communication with IPC
U1064 Loss of Communication with BCM
U1016 Loss of Communication with PCM
C2105 Right Front TPM Sensor Malfunction
C2110 Right Rear TPM Sensor Malfunction
C2115 Left Rear TPM Sensor Malfunction
what could have caused this? No spark? No fuel?
car has about 105K, any insight will be helpful.
TIA
TIA
how is the battery on the car? when the batteries go bad on these cars they go crazy. also check all grounds and make sure they are all clear of corrosion and are not loose
Hello all.
TIA
TIA
battery connections are good. its sooooooo dirty under my hood i didnt even bother to check for anything else. she will get a very deep cleaning this weekend
I'd look at chassis grounds 1st, read the electrical stick at the top of the section.
Also the wiring in the passenger door acordian is a KNOWN issue causing all kinds of issues like this. I think this is also covered in the electrical sticky.
it happened again on the freeway for about 2 seconds. this time Check engine light came on.
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
time for a new MAF?
time for a new MAF?
well i think i know what was wrong with my car. at first i thought it was the wires from where it plugs in.. but then i found out it was worst. does any one have a PN for that?
i think i found the AC delco P#. can someone confirm this is the right one before i buy? thanks
CONNECTOR-W/LEADS, 3-WAY F. *BLACK
Part Number: PT1604
Product Notes:
[Sensor-Mass Airflow Connector]; 3-Way female black
Per Vehicle: 1; Years: 1997-2000
Part Number: PT1604
Product Notes:
http://www.lsxtune.com/shop/product_...oducts_id/1084
I'm sure you know you can purchase the chaffed wire loom at most auto parts stores. Why not by a new connector pigtail ?
i made it very short to prevent this from happening again
