Which States require an "OBD II" smog check?
Old 03-09-2010, 10:17 AM
SDLS1Rider
SDLS1Rider's Avatar
Default Which States require an "OBD II" smog check?
This has been proposed in California...
Proposed California OBD II smog check
The article says that 22 states including Nevada have this already in place. I was just wondering if I could get some feedback on what enthusiasts do for mods and how they handle them in these states?
Thanks.
Old 03-09-2010, 10:33 AM
Z0GOON6
Z0GOON6's Avatar
in Illinois they check the OBDII and if you are not throwing a cel you pass even if you are catless
Old 03-09-2010, 10:55 AM
ICULUKN-C5
ICULUKN-C5's Avatar
In AZ they ODB II... Thank God cause there is no way my car would pass a sniffer...LOL
Old 03-09-2010, 11:14 AM
redrckt97
redrckt97's Avatar
Texas has OBDII (in the big cities) .. tuners can make it pass easily
.. mine with cam-headers-hi-flow cats passed last 2 years easily.
Old 03-09-2010, 12:14 PM
Bowtie_Brigade
Bowtie_Brigade's Avatar
Just go to EPA's website and check for "non-attainment" areas. All areas in non-attainment will require "smog" checks.
Test type is determined by model year. I forget the cut-off years, but I believe OBDI (i.e., dyno/sniffer test) is for cars up to 1995 when they switched to OBDII. OBDII is merely a plug-in test into your car's main cpu. Your computer spills its guts unless it's been tuned
Old 03-09-2010, 12:34 PM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Received 1,319 Likes on 788 Posts
Georgia (counties around Atlanta only) is OBD I & II.
I took a twin turbo '02 Firehawk with an aggressive cam, no cats, 600+ rwhp and because there were no codes it passed.
The pre '96 cars (OBDI) still gets the roller/sniffer test.
Old 03-09-2010, 01:19 PM
BitViper
BitViper's Avatar
Thanks.
They do plug into the system here..and if your throwing a code... you fail!
Old 03-09-2010, 01:30 PM
chaase
chaase's Avatar
St. Jude Donor '12
NY has ODBII and it is easy for cars to pass the computer. All you need is a competent tuner. They still do a visual check, but most places are not very thorough so even if you have long tubes, just keep your cats.
Old 03-09-2010, 01:46 PM
AU N EGL
AU N EGL's Avatar
http://www.obdclearinghouse.com/
OBD Clearing house has the listed states and updates
Old 03-09-2010, 03:24 PM
SDLS1Rider
SDLS1Rider's Avatar
I always assumed that. Which begs the question why is this proposal a problem for anyone? It seems the main change is the elimination of the dyno treadmill and sniffer.
Old 03-09-2010, 03:39 PM
chaase
chaase's Avatar
St. Jude Donor '12
It is a good thing. I love that they have the ODBII stuff here. I can do pretty much whatever I want to my car and it will pass smog.
Old 03-09-2010, 03:48 PM
rwlc5
rwlc5's Avatar
Maryland requires it, but when I took the vette the last time, they didn't even check it. They gave me a waiver.
Old 03-09-2010, 04:49 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Pretty much. It goes by county here with the larger cities (and all surrounding contiguous counties) being required also.
Old 03-09-2010, 08:12 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
Thanks.
In my area of NY they check the computer and do a visual inspection. If the cats have been given the broomstick mod they will not know it if the computer shows no problem. Older cars get a visual. Basically the visual is a quick glance and if it looks right it will pass.
Bill
Old 03-09-2010, 08:25 PM
Chalky
Chalky's Avatar
5 counties in SE WI. Every two years OBDII plug in. Better than rollers.
No visual!
Old 03-10-2010, 11:50 AM
BitViper
BitViper's Avatar
ITs always pissed me off about CA.. If the car is meeting the state standards for emissions who cares whats between the intake and the exhaust...
The last time I smogged I went three rounds with the testing shop and the state over my Vararam intake... a frickin INTAKE.. air comes in.. then leaves....done.
What I discovered is that the person doing the testing has the discretion on whether or not a part is actually exempt.. Somethings are obvious.. headers blowers etc.... but things like a catch can valve cover breathers and CAI's are "unclear" ... Believe it or not....I got conflicting opinions from two state agencies and a state referee on my Vararam..... so frustrating
Old 03-10-2010, 12:09 PM
Bowtie_Brigade
Again, the type of test is dictated by the year of the vehicle. You can't run an OBDII test on a OBDI vehicle.
OBDI (pre-1996) = still requires sniffer/dyno test
OBDII (for most states) = Diagnostic plug-in into your cars computer
Only states, and their respective areas/cities that are in non-attainment for air quality standards per the Clean Air Act will require the testing.
Old 03-10-2010, 05:26 PM
C5 Curmudgeon
C5 Curmudgeon's Avatar
NJ does it.
To Which States require an "OBD II" smog check?
Quick Reply: Which States require an "OBD II" smog check?
