How do I remove door panel/fix rattleing window
The drivers window is loose tiping in and out. I'm looking for How to's on getting the panel off and tightening the window to fix the rattle.
Anybody done this before?
Thanks,
Rick
Thanks,
Rick
St. Jude Donor '07
Re: How do I remove door panel/fix rattleing window (Bugster57)
To get the panel off, pop off the small piece behind the door handle and remove the screws. Then take a flat butter knife and insert it under the panel at the bottom and gently pry it away. They're just those weird plastic 'bolts' that are press fit. Work your way around and it will all pull away at the bottom. Reach in from the bottom and disconnect the plug for the power windows. Life up to get the panel off.
As for adjustment.....
Tom
Tom
Bugster57,
The driver side window on my 1999 C5 coupe (22,000 miles) also rattles when it moves in and out (grasping the top of the window glass and moving it back and forth).
Anyone have any ideas?
1999 White C5 Coupe
1999 White C5 Coupe
Re: How do I remove door panel/fix rattleing window (1999 White C5 Coupe)
I have MS powerpoint file on how to fix a C5 mirror that shows how to get the panel off if your interested!
Re: How do I remove door panel/fix rattleing window (C54TIM)
We would love to see the file, it can't hurt. Mine is a lil loose as well. I've been debating on whether to try and fix it myself, or have someone else do it. Guess i'll give it a shot! :yesnod:
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
anyone know what size that torx screw behind the handle is, before I have to run to the store :D
CI III & IV Vote Ho
CI IV Bracket Champ
hmmmmm, the 30 I just bought seemed to fit at the store.....DAMN, "running to garage to look" :eek:
Re: How do I remove door panel/fix rattleing window (Mean Green 2000)
What ever works is my mod-oh!
Could have been a change? But I took my 02 panel off the same way? To add the window commander!
[Modified by C54TIM, 10:05 AM 3/10/2002]
CI III & IV Vote Ho
CI IV Bracket Champ
:D....very weird, the 30 worked, all's well that ends well :D
