Tool question
Tools
I still have many of my Craftman tools I bought 40 years ago.....I have lived in more places than I can remember.....but I have Never had a problem returning a tool to Sears anywhere. But make sure you buy Craftman....because I dont think the "Sears" brand has the same lifetime warranty.
Snap on????dealers are sometimes reluctant to replace broken items unless you bought it from them.....although they are suppose to exchange even items not bought from them.
HF great for that odd ball item you need and they are cheap....as I said tools go Craftman
That's pretty cool. I have a broken Craftsman 1/2 in Drive Ratchet. You mean all I have to do is bring it in and heave it on the counter and they'll run and get me a new one?
Received 2,182 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BC
They had a policy in effect a couple of years ago where they provided/installed if necessary, new "guts" for the ratchets as opposed to replacing the entire ratchet.
I've only replaced one 3/8" ratchet since I've been buying CRAFTSMAN tools. The ratchet had a better ergonomic shape than the newer versions that they may have replaced the tool with. I was happy to have new guts and keep my favorite old ratchet.
I like craftsmen, but I'll buy the Lowe's stuff as well. Husky is not one of my favorites.
BTW, last I heard Craftsman was still being made in Colorado by the same guys making Snap On. This was over ten years ago so I don't know if anything has changed since then.
I've replaced a 3/8 and 1/2 Craftsman ratchets over the last year. In both cases, it was a direct exchange.
I would say 70% of my tools are Craftsman and the rest came from Harbor Freight. I love that place! I have never had a problem with any of their tools. I have some that are 4 or 5 years old and still work like the day I bought them. The only thing I wont buy from them are my ratchet sets, but sockets and what not Ill get at Harbor Freight.
About 70/30 for me also. I needed a 1/2 ratchet - $27 Sears vs $9.99 HF - so I got HF one. When I repl motor, we tried to break it many times, never broke and still using today. But then again, I am not professional grade. I have no problem buying their Pittsburgh tools. My std size wrenches and sockets are craftsman, but deep well, odd sizes are HF.
They are a good deal for light use
My real tools are Snap-On
While Snap On is expensive, there is no finer tool made. You can find them for reasonable prices on ebay if you take your time. My personal rule is not to pay more than 50% of retail. Some folks will bid them up, but 50% works for me.
Good luck, I don't think you can go wrong with a good set of Craftsman as a starter set.
GUSTO
A few of the tools in my tool drawers are from my father's and have to be around 50 years old. Craftsman 1/2 ratchets and breaker bars and SAE sockets, all still like new. He used to inscribe his initials on all his tools, so I know what I see a GS on one, it once was my Dad's. It's good to have the mixture of metric and SAE. I also have a shorter micro-torque and standard torque wrenches from Craftsman. The micro-torque covers that lower to mid range, and the larger those upper requirements, plus the micro-torque is necessary for lack of room to operate the wrench. I think it was less than $150. for the two combined.
#34
Wounded Warrior Escort '11
#35
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I have just about every manufacturer of tools in my box. I agree older Craftsman is better than the newer stuff in the last 15 to 20 years. As mentioned they don't warranty torque wrenches but I took mine in over 10 years ago because of a stripped gear in the head. They went in the back and came out with a rebuild kit for a 1/2" drive ratchet which fit the torque wrench. The last few times I went to Sears to exchange tools they had a bad attitude about it.
Snap on sucks to exchange things with. They will go as far as just replacing the blade of a screwdriver and not the handle.
Harbor Freight is OK. I bought their 40" roll chest and top for under $500. Ball bearing drawers, heavy gauge steel construction, heavy duty large casters. If you bought a comparable set from any other company you're looking at $1500. to $3000.
Lately I've been buying GearWrench stuff. I love the flex head ratcheting wrenches. Fine tooth ratchets with the 180 degree flex head gets me into areas you can't get with normal wrenches or ratchets.
#36
There are already copied versions by the competitors. Matco has Opti-torque and Mac has Knuckle savers. Mac has some really cool sockets out there that have ridges in the socket on the flat surface between the intersections. They grab well on 60% stripped heads.
#37
For those that are curious about Craftsman hand tools: the mechanic's hand tools have been made by a variety of manufacturers over the years including New Britain[6], Moore Drop Forge, Easco Hand Tools[7], Stanley, and most recently the Danaher Corporation.[8]
#38
Then the patent has expired
#40
About 10 years ago I purchased a small 1/4" drive set from Lowes (Kobalt). I was examining the sockets in the set and noticed that they were Flank Drive (they had the fillets machined between the flats internal to the sockets). As I was reading the brochure that came with them, I noticed that they were manufactured by JW Williams, a division of Snap On Tools. If you check out the Kobalt tools today, you will notice that they no longer have the fillets machined in them.
I have no doubt that Lowes switched manufactures to keep costs down for the vast majority of their customers. Make no mistake, I believe that Lowes/Kobalt makes some excellent tools that will serve the vast majority of hobbiests well.
I do find it ironic that some of the same people that will quibble over the cost of Snap On tools, have no problem spending $800-$1000 per wheel for the very car they are willing to use bargin basement tools on...
Good luck and keep on wrenchin' regardless... GUSTO
