loud clicking noise
loud clicking noise
driving home from work (not racing) and all over sudden i stated to hear a clicking noise from the engine compartmnet..... it got louder and louder and sort of started to loose power...... i made it home 5 miles of driving... car idles fine no boggin, I popped the hood and it sound like a bend pushrod.......
No codes in DIC....
any ideas????
thnks guys
No codes in DIC....
any ideas????
thnks guys
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Excellent advice! Look for a damaged rocker (internal roller bearings falling out) , loose or bent push rod and or broken spring.
In most cases..no. Like Bill stated, you may have lost the bearing(s) from a rocker. If that's the case, replace the rocker, and drain the oil, because the bearings have probably traveled to the pan. You may find a cracked spring, which just requires replacement. If you find a bent pushrod, the head may have to come off, but a leak down test will tell you that.
In most cases..no. Like Bill stated, you may have lost the bearing(s) from a rocker. If that's the case, replace the rocker, and drain the oil, because the bearings have probably traveled to the pan. You may find a cracked spring, which just requires replacement. If you find a bend pushrod, the head may have to come off, but a leak down test will tell you that.
what tools will i need????
ok i took the valve covers off (both sides) and everything is in place.... i even called a buddy of mine to give it a double check and he agreed that everything was good in the valvetrain
so i put the valve covers back.... and fire the car up after 2 weeks for my buddy to hear the noise... the car starts up and the noise is there off coarse.... but after 5-6 min of idling the noise is gone completely.......
weird, it sure sounded like some thing was loose in the valvetrain....and now its fine??
i recorded a video but i dont know how to post it... i can email it though
thnks guys
thnks guys
thnks guys
thnks guys
But how does the engine run under load? Have you taken it out on the street?
You may have a lifter that is starting to go south on you. If it collapsed earlier then you would have had the loss of power and valve train noise.
