Head & Cam on my 1999 1st day
#82
you sissy's and your impacts...I never had a problem getting the crank bolt out with just a half inch rachet/socket and a small breaker bar...did probably 7 or 8 this way
#84
Wrap your dampener loosley in HD in foil Heat it up to 250 to 275 degrees Fairinheight for approx 30 to 45 monutes. No more than that. Your front seat can handle a temp about 100 degrees more than that without distorting. This will ease your cranking and it will only have a few turns to go. 240lbs tq is no easy feat bu with the heat help shouldent be to har at all. Cant wait to hear a video after the work is done.
#85
MFIC
Ok, last night I did remove the timing cover and found out I could not longer turn the crank by hand, so time to make another tool.
With the oil pump out of the way
With the pump out, new parts to make tools. Here is the new crank turning tool, made with the rotor of the old oil pump rotor.
Fits like a glove
Gears and chain out of the way, the chain had a lot of slack on it
Water pump bolts in
Cam out
Fits like a glove
Water pump bolts in
Cam out
#87
Former Vendor
Nice ideals on making your own ls tools.
#91
MFIC
MFIC
Slowly but surely this thing is going back together.
Last edited by ILM-Express; 01-28-2010 at 11:02 PM. Reason: remove double posted picture
#94
MFIC
Curious if you used Loctite on the cam sprocket bolts? A few guys had them back out and there have been some cases of them backing out from the factory build.
#96
MFIC
MFIC
The garage has been very cold at night (below 30) so my project is on hold.
I also have a very bad cold, so no more work until it warms up a bit.
