fog lamp bulbs c5
Old 01-05-2010, 09:41 PM
TOPKATTKG2
TOPKATTKG2's Avatar
Default fog lamp bulbs c5
Hi all, I know I have seen the part number for higher watt fog lamp bulbs for a c5 on the forum but I can not find it again. Can anyone tell me the watt size and the part number? thanks in advance
Old 01-05-2010, 09:52 PM
ALLEGRO
ALLEGRO's Avatar
Stock is the 899 (37.5 watt) bulb. I upgraded to 885's (50 watt) with lots of improvement. A simple and safe upgrade.
BUT....most importantly, re-aim your fogs. They are set from the factory WAY too low. Do a search, I think there is an exact number of turns to get you in the ballpark.
Good Luck
Old 01-05-2010, 10:07 PM
TOPKATTKG2
TOPKATTKG2's Avatar
Default fog light bulbs
thats exactly what I was looking for, thanks again
Old 01-05-2010, 11:03 PM
JW Motorsports
Banned Scam/Spammer
JW Motorsports's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Good Luck
http://www.c5forum.com/diy/fog_lamps.php
thunder1951 (08-17-2017)
Old 01-06-2010, 11:46 AM
bighank
bighank's Avatar
Default If you use 885s and reain the lights higher you almost don't need headlights
Replaced my fogs with 885s about 5 years ago. Reaim the fogs by parking say 15 - 20 feet from a white garage door or something like that. Use the low beam height to set the fog light height. Can only go up and down with a Torx wrench but thats OK. The 855s are 50 watts and are almost as bright as the headlights. Can turn on the parking lights and the fogs and not use the headlights unless its really dark.
BIGHANK
Old 01-06-2010, 01:24 PM
jpandes
jpandes's Avatar
You can run HID's in them...
Old 01-07-2010, 10:27 PM
Van5150
Van5150's Avatar
Who makes HID's for them?
Old 01-07-2010, 10:44 PM
Plasticman
Plasticman's Avatar
BIGHANK
Just beware that if the fog bulbs contact the black plastic surround (when adjusting them "up"), the plastic will melt (can see the plastic smoke and melt at night).
Don't ask............
Plasticman
Old 01-08-2010, 07:52 PM
TOPKATTKG2
TOPKATTKG2's Avatar
thanks a lot, you guys are awesome on this forum, i am always pleasantly surprised by all the great info given, and they come from all over the country. tom g.
Old 01-08-2010, 08:55 PM
kevin40zx
kevin40zx's Avatar
I agree go on fleebay and get the HID upgrade its well worth it.
Old 01-10-2010, 08:52 PM
bighank
bighank's Avatar
Default No Melting after 5 years when should I expect this to happem?
Plasticman
Have had the 885s in for 5 years and always run them with the low beams. Have not seen any problems.
BIGHANK
Old 01-10-2010, 10:45 PM
Plasticman
Plasticman's Avatar
BIGHANK
Please read what I said................ In other words: If you adjust them too far up, and they contact the plastic surround, it will melt the plastic.
If you are looking for them to melt the plastic, then just raise them up further!
Plasticman
Old 01-10-2010, 10:48 PM
JW Motorsports
Banned Scam/Spammer
We have them http://www.shop.jwmotoring.com/produ...7&categoryId=4
100% Plug n Play
Old 01-13-2010, 07:43 PM
bighank
bighank's Avatar
Default I guess not using them as airplane searchlights does the trick
Plasticman
I have raised them only to the height of the low beam headlights as looking for planes went out after WW2. I hate when people have the lights set to BLIND ALL ONCOMING TRAFFIC. But raising them a little does a whole lot for illumination with the 885 bulbs installed.
Incidentally I used the 889s or 892s from my C5 on my Pontiac Montana which had even lower wattage bulbs but with the same configuration. Got more brightness there too.
BIGHANK
Old 01-15-2010, 08:02 AM
Slider-01
Support Corvetteforum!
Slider-01's Avatar
How hard is it to swap the bulbs?
Old 01-31-2010, 11:53 PM
bighank
bighank's Avatar
Default Not hard at all just time consuming
Remove about 6 small bolts on each side on the shrouds under the fog lights and move the plastic brake cooling duct to get to the back of the fog lights. Reach up and remove the lamp and cable going to the lamp and replace with an 885 bulb. Replace bulb, brake cooler duct and shoud and bolts then re-aim lights as I indicated above with a Torx driver and in front of something light like a garage door using low beam lights as a guide.
Have fun. BIGHANK
Old 02-01-2010, 03:56 AM
DeeGee
DeeGee's Avatar
Here's a few pics to help:
Document ID# 780025
2002 Chevrolet Corvette
________________________________________
Fog Lamp Bulb Replacement - Front
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Remove the front fascia lower close out panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
3. Release the brake caliper cooling duct from the front fascia and position the duct aside.
4. Disconnect the front fog lamp electrical connector from the fog lamp bulb/socket.
Caution
Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass fragments. To help avoid personal injury:
o Turn off the lamp switch and allow the bulb to cool before changing the bulb.
o Leave the lamp switch OFF until the bulb change is complete.
o Always wear eye protection when changing a halogen bulb.
o Handle the bulb only by its base. Avoid touching the glass.
o Keep dirt and moisture off the bulb.
o Properly dispose of the used bulb.
o Keep halogen bulbs out of the reach of children.
5. Remove the fog lamp bulb/socket from the fog lamp.
6. Rotate the fog lamp bulb/socket counter-clockwise to release it from fog lamp.
Installation Procedure
1. Install the fog lamp bulb/socket to the fog lamp.
2. Rotate the fog lamp bulb/socket clockwise to secure it to the fog lamp.
3. Connect the front fog lamp electrical connector to the fog lamp bulb/socket.
4. Position the brake caliper cooling duct to the front fascia, and press to secure.
5. Install the front fascia lower close out panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
6. Lower the vehicle.
7. Check and adjust fog lamp aim as necessary. Refer to Fog Lamp Aiming Procedure
To fog lamp bulbs c5
Old 02-01-2010, 12:13 PM
Slider-01
Slider-01's Avatar
Done, piece of cake!
Old 04-22-2018, 07:34 PM
Key2power
Key2power's Avatar
Question I have a 2000 C5 don't have fog lights does any one know if the wiring is there just in case you might want to install fog lights
Old 04-22-2018, 07:41 PM
Key2power
Key2power's Avatar
Quick Reply: fog lamp bulbs c5
