C6 Z06 front spring fit a C5 ?
Old 12-28-2009, 04:20 AM
rustyguns
rustyguns's Avatar
Default C6 Z06 front spring fit a C5 ?
from what i have read c6 and c5 front ends are pretty similar...
would the spring fit a C5?
if so anyone know .... the spring rate of a C6 Z06 front spring?
Old 12-29-2009, 12:45 PM
Dans99C5
Dans99C5's Avatar
Old 12-29-2009, 01:19 PM
marinehacker202
marinehacker202's Avatar
Old 12-29-2009, 05:15 PM
rustyguns
rustyguns's Avatar
one guy in a different thread said it does fit but.......... i have z51 and the spring rate is almost the same
Old 12-29-2009, 11:47 PM
marinehacker202
but hmm, if we could use C6Z springs... I'm interested for sure now
Old 12-30-2009, 12:10 AM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
I assume it would work...but as far as spring rate goes, it was designed to hold up a 7.0L motor as opposed to a 5.7L. Should be stiffer in theory. Interested to know if anyone has tried.
Old 12-30-2009, 12:58 AM
rustyguns
rustyguns's Avatar
C5Z 526/714
C5T1 582/793
C6Z51 526/645
C6Z06 531/782
C6T1 582/850
comprende?
Old 12-30-2009, 01:36 AM
lucky131969
lucky131969's Avatar
Just because the displacement is larger, does not mean the engine weighs more.......
Old 12-30-2009, 01:41 AM
lucky131969
Old 12-30-2009, 03:20 PM
ArKay99
ArKay99's Avatar
What are those weights based on?
The LS1 is almost the same motor as an LS6.
Could that be the difference between a clutch/fw/pp combo and a flexplate? Still seems heavy unless one has the harness and ECU piled on top of it too.
Old 12-30-2009, 03:23 PM
lucky131969
Straight out of the GMPP catalog.
Old 12-30-2009, 04:05 PM
SDPC
Premium Supporting Vendor
SDPC's Avatar
Those weights aren't right at all. The LS6 weighs 50 pounds more than an LS1 and an iron block 5.3 weighs less than the LS6 and only 20 pounds more than an LS1? I'm not sure how they obtained those weights, but something isn't right.
Old 12-30-2009, 04:25 PM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Here is some numbers for you:
Since you mentioned Z06 springs, for rate comparison purposes:
C6 Base Springs(lbs) Fr 420/Rr 657, Sways(mm) Fr 25.5/Rr 17.5
C6 Z51 Springs(lbs) Fr 526/Rr 645, Sways(mm) Fr 31.0/Rr 25.6
C6 Z06 Springs(lbs) Fr 531/Rr 782, Sways(mm) Fr 31.0/Rr 27.9
Sourced from:
http://forums.corvetteforum.com/1569355821-post9.html
Thanks,Matt
Old 12-30-2009, 04:28 PM
rustyguns
rustyguns's Avatar
Originally Posted by lucky131969
nice numbers! thx
rustyguns
rustyguns's Avatar
Sourced from:
Thanks,Matt
I completely concur..
Old 12-30-2009, 04:39 PM
lucky131969
Ok, since you guys deal in crate motors every day, what are the correct weights?
Old 05-04-2010, 04:22 PM
RichAshley-Black99
RichAshley-Black99's Avatar
So can you use the springs or not
To C6 Z06 front spring fit a C5 ?
Old 05-04-2010, 06:51 PM
Dope
Resident moron
Dope's Avatar
I agree. I'm sure that they weighed them with different options though. Maybe some are/aren't wearing wearing exhaust manifolds, and/or flexplate/clutch assembly? Plus computer, wiring harness.
They should all be pretty much the same weight.
The LS7 might be a little lighter with titanium rods but then you have to add in the dry sump oiling system which I'm sure adds a pretty considerable amount of weight (nevermind the oil itself).
Dope
Old 05-04-2010, 09:00 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
I think the C6 springs do not fit a c5 in front or rear not sure ask in the RR section.
Old 08-04-2013, 07:30 PM
typeav
typeav's Avatar
The C6 ZO6 Springs front and rear yes fit on any C5, I just add the 2013 ZO6 Springs and Sway bar to my C5 2003, the improvement is amazing but the car is going to look high, here are the picture of my C5 with the ZO6 suspension.
Quick Reply: C6 Z06 front spring fit a C5 ?
