Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-09-2009, 11:29 AM   #1
FRC Z
CF Member
Default Can a bad REAR O2 sensor cause decreased gas mileage?
I have noticed that the gas mileage on my '02 Z is fairly low lately compared to what I should be getting. Cruising at 50mph in 6th gear I am only averaging around 26mpg and it just gets worse from there. Probably about 21.5mpg at 65mph.
For a while now my car has been throwing a P0140 code. Before I figured "It's a rear O2 and those are just for emissions. Who cares?". But now I'm wondering if this may be the cause of my problem somehow. For a while I have just been clearing the code to get my CEL to go off. It is the ONLY code that ever shows up.
Note: I have not noticed any decrease in performance. The car feels just as strong under heavy throttle as ever. Approximately 74,000 miles on the clock. New plugs and wires around this time last year.
Could a bad rear O2 sensor possibly have anything to do with my poor mileage or should I look elsewhere?
FRC Z is offline   Reply With Quote
Old 12-09-2009, 12:11 PM   #2
FASST LN
CF Senior Member
FASST LN's Avatar
Not sure if it being in the rear makes a difference, but I do know that in general a bad O2 sensor will hurt your gas mileage.
FASST LN is offline   Reply With Quote
Old 12-09-2009, 12:14 PM   #3
vettenuts
CF Senior Member
vettenuts's Avatar
Send a message via AIM to vettenuts
Check my thread on "A funny thing happened on the way to the dyno". It could be the fuel, although your drop in mileage is rather large on a percentage basis. Do you know if Texas switches to the winter blend which contains higher butane levels? If so, mileage will go down. My truck is down for the last few fills which I now attribute to the fuel.
vettenuts is offline   Reply With Quote
Old 12-09-2009, 02:12 PM   #4
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
NO! The rear 02 sensors ONLY provide the PCM CAT Efficiency data. In NO way are they used to compute air/fuel ratio for the PCM.
They just tell the PCM if you comply with emissions by having properly operating CATs
VETNUTS has some intriguing info and it and his post is an interesting read.
BC
Bill Curlee is offline   Reply With Quote
Reload this Page Can a bad REAR O2 sensor cause decreased gas mileage?
Tags
bad, c5, corvette, decrease, excessive, faulty, gas, mileage, o2, oxygen, poor, rear, sensor, sensors, wnat
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
