NHTSA.gov fuel leaks
St. Jude Donor '08-'09
NHTSA.gov fuel leaks UPDATE 01/09/10 PLEASE READ LAST POST
everyone that has fuel leak problem, fuel vapor smell, leaks on the fuel system dealing with the crossover or tanks, or anyone that has had this already fixed, please send a complaint to (NHTSA.gov).
I didnt know about this until yesterday, and filled out the complaint. You will need your vin number.
This is a faulty system designed by GM and they should be held accountable for it.
Last edited by dadsturn; 01-09-2010 at 08:06 AM. Reason: VERY IMPORTANT NEW FOUND INFORMATION
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What is the reported /monitored issue?
BC
BC
Mainly the 2004 models and it takes a fuel tank replacment to repair.Some have cracked tanks and some have a crossover pipe seal issue that takes a tank replacement to fix.this is both a safety and an emmission law issue!
What you are saying is VERY true. Unfortunately however, unless there have been documented injuries or deaths that were caused by this defect, nothing will be done by the NHTSA or GM to correct it.
Many of us have followed the same dead ended trail seeking replacements for our cracked thin spoke wheels.
NavyGunner1980 (06-01-2016)
Senior Member
Cruise-In V Veteran
Then it becomes a matter of how large a class can be mustered to bring this action. That is usually the weak link in bringing these types of actions. Normal aging is not covered. What is the life expectancy for the parts that are failing. Nothing lasts forever.
If GM is notified of a fuel leak issue and it is widespread without them taking any action they have a huge problem. It is like pulling the pin on a handgrenade and continue to hold the grenade. It would put them into a situation where punitive damages could be sought. Ford Motor Company ignored the issue with their Pinto and its gas tank issue. It cost them dearly too.
Senior Member
Cruise-In V Veteran
see https://www.ftccomplaintassistant.gov/
Senior Member
Cruise-In V Veteran
your response is an emotional one. fortunately I have dealt with these issues on a professional basis. some people are experienced and educated and some are not. ignorance is bliss . think with your brain not your emotions
I got a call from the NHTSA today,another member also got a call.They are very interested and want pictures and parts for their lab. Seems there is an agency that will help.This is also an evaporative emmission issue which carries a 80,000 mile warranty!
What about fuel filter leaks ?
A lot of us, me included have had the fuel filter leaking. Isn't this an issue ? I realize that this is easily and relatively cheap to fix, but it leaks very close to the exhaust pipe and is also an emissions problem.
TTT
UPDATE
Recvd. call from Nathan@ NHTSA. He only shows 4-5 reports on the books for this problem. He stated that this could come to a head very quickly if everyone that has this problem would report to him.
He stated that even if you have had the leak fixed by paying or Warranty, to send in this complaint. For those that have paid to get it fixed, they are making sure that you are returned your money that you paid.
Everyone needs to take the time to file this complaint.
UPDATE
