A4 Guys! I Need Your Help/Opinions!
With the mods listed below, conservatively, what do you think my 1/4 mile times should be. I'll be on stock run-flats, but this converter has a 1.9 STR so traction shouldn't be too great a problem. Thanks!
Re: A4 Guys! I Need Your Help/Opinions! (XTrooper)
I would say low 13's maybe high 12's. It will really depend on if you can hook up or not. When my car was stock with the run flats on I ran 13.2's, but only at HRP. Any other track I couldn't hook the tires up and spun through the 60 ft.
I have no track experience but from what I've learned on the forum I'd guess about 12.5-12.8 range. How'd I do did I pass the quiz?
I would guesstimate between 13.0-13.5 with runflats. On runflats with the mods listed in my signature minus the LS-6 Intake, I ran a 12.79 @ 110 on an 80 degree day at Englishtown. Then again, I'm sure that an expert driver would have done better with my car than I did. I just wait for green and go, no revving up to a certain RPM level or anything special.
I would guesstimate depending on how well you drive, the weather, traction about a 12.6 - 12.7 area... but it all depends I put my 2002 A4 in the 12.7 area many times with Corsa Exhaust and Halltech Sidewinder!!!
Good Luck to ya :cheers:
Re: A4 Guys! I Need Your Help/Opinions! (Hissey)
Re: A4 Guys! I Need Your Help/Opinions! (vettvert)
Steve
Re: A4 Guys! I Need Your Help/Opinions! (C5Owner)
C5Owner: I went to Prairie Hill and Temple Academy Dragway. Night I went to TAD no one was hooking up. Bad track prep. I would not recommend Prairie Hill for a C5. It's not the smoothest track after the traps. My anti-locks keep coming on. :D
I ran 12.73 @ 108 recently. I would say my HP and yours are about the same. You have an edge on the exhaust (mine is semi-stock) but I think the 2002's are a little stronger than earlier years so maybe that evens things out.
Your Yank and programmer should help by 0.3 to 0.4.
I am guessing 12.3 to 12.5 with good weather (cool, 50 degrees, dry) and 60-foot time at 1.9-2.0. Launch at 1200-1500 and you will get in the 1.9's all day long. My 60 foot ET average for 15 runs to date is square in the middle of 1.9-2.0.
Let us know!!!
Roger
Let us know!!!
Roger
My A4 runs 13.2's to 13.4's...........
Re: A4 Guys! I Need Your Help/Opinions! (BLUECOUPE)
Steve
[Modified by XTrooper, 6:24 PM 2/27/2002]
XTrooper,
I ordered a Yank 3000 today from Richard at Exit28(supporting vendor). I should have it installed either Friday or early next week and will let you know how my 1/4 time has changed. When I ordered my Powerloader last year, I went ahead and told them to set it up for a Yank 3000. I am finally taking the plunge.
Re: A4 Guys! I Need Your Help/Opinions! (abraham)
I love mass intoxication and high horsepower cars.
X trooper
R u the same x troop as on ls1.com? anyway I think they have a program called desktop dragstrip that can ansewer most of this stuff...I dont have it though.
