C5 differential rebuild procedure
Old 11-11-2009, 06:16 PM
sprinter
sprinter's Avatar
Default C5 differential rebuild procedure
Just thought I would share the GM procedure for complete overhaul of the C5 differential (torque settings, gears, bearings, clutches, dissassembly, assembly etc.). When viewing, it makes it easier if you rotate the pdf clockwise 90deg.
For the search function: diff differential gears rebuild repair overhaul setup
https://docs.google.com/fileview?id=...YWZmM2Jj&hl=en
Old 11-14-2009, 03:21 PM
Tech
Tech's Avatar
Thanks for sharing this.
Old 11-15-2009, 08:36 AM
tommie
tommie's Avatar
good link!!
Old 07-29-2010, 09:49 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Excellent information.. Thanks for posting
Old 02-06-2015, 03:46 PM
sjfd20
sjfd20's Avatar
Anybody have any idea of the approximate cost from a private shop if you didn't want to rebuild your differential youself? I'm in N.California I have a C5 six speed
To C5 differential rebuild procedure
Quick Reply: C5 differential rebuild procedure
